R50/53 What info your MINI stores
Old May 4, 2007 | 07:44 AM
jakay11's Avatar
jakay11
I did a quick search and came up empty...
Does anyone know what info the black box stores?
Number and duration of full-throttle hits?
Top speed recorded?
anything else?
TIA!
Old May 6, 2007 | 07:53 PM
HighSchoolzMINI's Avatar
HighSchoolzMINI
im not really sure, but my dealer smirked at me and commented on how i have a heavy foot,
Old May 6, 2007 | 11:30 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The idea of a black box frightens me, you know, big brother and all. Do all MINIs have them or only the newer ones? Is there a way to remove it?
Old May 7, 2007 | 04:39 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
I thought the 'heavy foot' was a standard option on all MINIs?
Old May 7, 2007 | 06:05 AM
DixonL2's Avatar
DixonL2
Do a Google search on OBD2 or OBD II. The Mini key also apparently is able to tell the dealer a few things...
Old May 7, 2007 | 10:51 AM
caminifan's Avatar
caminifan
The primary use of the Event Data Recorder (EDR, otherwise known as the Black Box) is to aid in diagnosing intermittent problems that are sourced in the car's electronic control systems (DME, ABS controller and the like). Without the EDR logging system status conditions, it is almost impossible to diagnose and fix/replace an intermittent problem. The downside of EDRs is that they keep track of conditions the entire system is experiencing (such as engine speed which can be extrapolated to vehicle speed). All BMW-built (2002+) MINIs have EDRs. Removing/disabling the EDR is a doubtful proposition - you probably would not be able to start the car after removal/disabling the EDR.
Old May 7, 2007 | 01:36 PM
chows4us's Avatar
chows4us
Its not the OBD2 ... that comes with ALL cars. As Camini explains, its the EDR or black box. They are being used to see what happens just before an accident.
Yes, data can be used against you.
see https://www.northamericanmotoring.co...ad.php?t=77172
Old May 7, 2007 | 02:00 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Which year MINIs started having recording keys?
Old May 7, 2007 | 07:49 PM
HighSchoolzMINI
well its not an option but it is a side effect
Old May 7, 2007 | 08:45 PM
caminifan's Avatar
caminifan
2002 and later.
Old May 8, 2007 | 11:56 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I see...what if you give the dealer the valet key that you never use to drive with?
It's not that I have anything to hide though, it's just that I don't really don't like the big brother idea and I'm a private person.
Old May 8, 2007 | 04:06 PM
caminifan's Avatar
caminifan
While some information may be recorded on the ignition key, it is not much (things like VIN, service campaigns, etc. would be the limit of what would be recorded on the ignition key). The EDR is more like a flash memory chip that records much more data points on a moving time series (like the last 2000 ignition events). Actual datapoints and how long of a data stream are recorded vary by manufacturer, but you can be sure the most recent ones will be stored for future retrieval if the need arises.
All manufacturers have some sort of EDR, so get comfortable with big brother being able to snoop on you if the need occurs. It is already happening with your e-mail: put the right combination of words in an e-mail, and protestations to the contrary aside, your e-mail will show up on a monitor for a decision on further action by a human being who is employed by a government agency.
Old May 9, 2007 | 03:30 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I think the ignition key only stores the VIN and the actual mileage of the car... but correct me if I'm wrong!
Old May 9, 2007 | 08:22 PM
Louispup's Avatar
Louispup
How about the little plastic (wallet) key? Will that tattle on me?
Old May 9, 2007 | 10:46 PM
caminifan's Avatar
caminifan
Doubtful. The current tattling facility requires electrical contact to be made. However, future Bluetooth-based functions could conceivably be placed in the plastic key. New BMWs (such as the E90s) have an option for keyless start.
arf88
May 31, 2016 03:07 PM
Mini'mon
Aug 26, 2015 01:02 PM
Alkaidovich
Aug 4, 2015 10:06 PM
