Nikon DSLR users
Old Mar 20, 2007 | 09:57 PM
SB's Avatar
SB
Nikon DSLR users
My wife purchased a D80 so I thought I would mess around with it. The included software, Picture project, for some reason give the pictures a green tint. Even when opening the factory included pictures.
What I'm looking for is a forum of some sort that does more than just review cameras. Something like a technical help forum. I did some searching on this forum in hopes and did decide to download the Nikon Capture trial. Same problem with it. The only way to view the pictures correctly on the computer is to set the camera to jpg and open them with Paint Shop Pro. Sort of a waste of a good camera. :impatient
Old Mar 20, 2007 | 10:18 PM
Disco's Avatar
Disco
Take a look at www.dpreview.com. Lots of info in the forums there.
Good luck!
Old Mar 20, 2007 | 11:42 PM
Sin MINI's Avatar
Sin MINI
I've had a D70 for about three years now and dpreview was where I spent most of my time (until I discovered NAM of course).
Cameras, lenses, software, computers (for the software), etc...best site on the web for digital camera buffs.
Old Mar 21, 2007 | 05:28 AM
ltphoto's Avatar
ltphoto
The absolute best place for all things Nikon is www.nikonians.org. Any help you need will be in the forums there. Also, get rid of Picture Project. It is close to worthless. Download Nikon View from the Nikon web site (free) and use that as your uploader - RAW converter - browser. If you have a color problem using Nikon Capture then you have a color setting wrong, or a monitor that is not calibrated.
Roy
Old Mar 21, 2007 | 07:40 AM
Rick-Anderson's Avatar
Rick-Anderson
I had the same problem with a Nikon camera I owned. I believe it was the white balance.
Old Mar 21, 2007 | 07:44 AM
valcom111t's Avatar
valcom111t
I've never used the Nikon software that came with my D70. I just drag-and-drop the files off the camera and then use my cheapo version of Photoshop for editing.
Old Mar 23, 2007 | 07:58 AM
texaspaul's Avatar
texaspaul
I have a d80 also!
I absolutly love it!
I would recomend joining Flickr!
There are lots of groups that can help you with anything!
you can see a few of my pics at www.flickr.com/photos/paulmetzgar
Old Mar 23, 2007 | 06:09 PM
valcom111t's Avatar
valcom111t
Flickr is great, but you're limited in how many sets you can make unless you want to pay monies.
Here's mine
http://www.flickr.com/photos/46424364@N00/
Old Mar 26, 2007 | 07:08 PM
Robin Casady's Avatar
Robin Casady
Sounds like a White Balance issue. What is the camera White Balance set at? You might want to set it at Auto if you don't want to change it when you change when you change lighting environments (sunshine, shade, flash, incandescent lights...).
I don't use Picture Project. I use either Nikon Capture NX or Photoshop CS2's Adobe Camera Raw plugin. So I'm not clear on how PP works. It could be that it doesn't pick up the camera's setting and you have to set it yourself.
Even if your WB setting is reasonable, it may not perfectly match the light under which you shot the photo. You may have to adjust it manually, or with a grey point eyedropper.
Old Mar 26, 2007 | 07:32 PM
dave's Avatar
dave
pug poo picker-upper
Agreed on this sounding like a white balance issue. Double check your white balance setting.
For broad daylight, I usually shoot jpeg with auto white balance.
For any lighting with flashes or night time, I usually shoot RAW so I have fine control over white balance. I do RAW processing with Nikon Capture mostly, and also use photoshop for other adjustments.
Old Mar 26, 2007 | 07:51 PM
Robin Casady
Originally Posted by dave
q1For broad daylight, I usually shoot jpeg with auto white balance.
Shooting JPEG, rather than RAW, gives you little ability to adjust your image later. It is fine if you are shooting high volume, and pretty much know what you are doing. The main benefits of JPEG are smaller file sizes, and lower post processing requirements.
With RAW, you have a lot more latitude for exposure adjustment in post processing. When shooting MINIs, you have a subject that can have a great range of brightness -- chrome in the sun and black tires in the wheel well. With RAW you have more options for recovering shadow detail and blown highlights.
Old Mar 27, 2007 | 01:46 PM
dave's Avatar
dave
I think there's a lot to be said for getting a good exposure in the first place. It's JMO that (as a general rule) shooting RAW in the middle of the day really isn't necessary.
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
MINIAC
Site Feedback
Oct 1, 2015 02:30 PM
MINI Stupor
Oct 1, 2015 11:36 AM
