Running SB-800 off camera?
Old Oct 26, 2006 | 10:17 AM
fj0's Avatar
fj0
How can I run the SB-800 off camera? What cable do I need? I know of pocket wizards but they are $$.
Is there a cable DIY? I want to learn lighting.
(Using Nikon D2x and one SB-800)
Old Oct 26, 2006 | 10:23 AM
dave's Avatar
dave
pug poo picker-upper
Originally Posted by fj0
Nikon D2x
Some options since you don't have a D70/D70s/D80/D200 that would trigger with the pop-up flash.
1) Get an SB-600 or 800 and fire that off camera using the SB-800 to trigger in commander mode. The plus side being you have a lot of flexibility with the SB-600/SB-800 placement.
2) Get a flash cord. I have one, but it's only 3 feet long (fine for photos with people, not very useful for cars)
Old Oct 26, 2006 | 10:38 AM
fj0's Avatar
fj0
That's what I thought. What about the cables, as I understood there are TTL cables and then there are "PC" cables? If you use the latter, you'll have to set the flash manually, right?
Nikon SC-28, but it's way to short, is there a DIY or something on how you can make it longer?
Old Oct 26, 2006 | 10:53 AM
MarkS's Avatar
MarkS
Yeah, for TTL you'll need an SC-28 or SC-29 cable. For manual, a PC cord will work fine. Paramount Cords sells custom length SC-28 and PC cords.
Mark
Old Oct 26, 2006 | 11:35 AM
speednut's Avatar
speednut
Would this Nikon SU-800 work also? Is it any cheaper than going with pocket wizards? I may need the same thing for my Kodak to get the SB-800 off the camera.
Old Oct 26, 2006 | 12:02 PM
MarkS's Avatar
MarkS
Yeah, that's designed to trigger the SB-800 (and SB-600) in place of a flash operating in master mode. Not sure how it works with the Kodak. I'd assume it would but I'm not positive.
It would, I think, be cheaper than Pocket Wizards (you'd need at least two), but possibly less versatile. You can't, for example, use it to trigger the camera and you're more restricted by distance and angle, though it works very well under a lot of conditions. The advantage of Nikon's Creative Lighting System is that you'd have TTL, if that matters much to you.
See the Sept 05 entry here: http://strobist.blogspot.com/2006_09...t_archive.html for a great comparison of CLS and Pocket Wizards.
Mark
Old Oct 26, 2006 | 12:10 PM
MarkS's Avatar
MarkS
Here's a direct link to the Strobist article:
http://strobist.blogspot.com/2006/09...-which-is.html
Mark
Old Oct 26, 2006 | 12:12 PM
dave's Avatar
dave
Yeah, but I don't think it makes much sense, that's why I didn't include it as an option.
That controler unit costs $250. An SB-600 is less than $200 and you'd get a second flash (by using the SB-800 as the controler). OR, for a little more than the price of the SU-800, you could buy another SB-800.
Hardware wise it's an option, but Nikon's pricing on it is a little screwy.
Old Oct 26, 2006 | 12:23 PM
G. P. Burdell's Avatar
G. P. Burdell
I use an SU-800 to trigger my SB-800s. I like the SU-800 because it's much lighter than a camera-mounted SB-800, and it makes an already heavy camera/lens combination a little easier to work with. Secondly, I don't work with an on-camera flash very much at all. Having an SB-800 on the camera just for the Commander mode seemed a waste of a flash unit to me.
The SU-800's greatest limitation is its useful range. On shoots where you have distant (>66 feet*) remote flashes that may not be within the SU-800's angle of coverage, you'll want to use Pocket Wizards instead.
*Nikon specified range - not necessarily the useful range
Old Oct 27, 2006 | 06:07 AM
fj0's Avatar
fj0
I just ordered these, http://www.flickr.com/groups/strobis...7594172539497/
Cheap and wireless, but if I didn't understood it wrong, you lose TTL, but oh well. I guess it has to be a little of a challenge or else its no fun.
Old Oct 27, 2006 | 11:14 AM
tsukiji's Avatar
tsukiji
I just bought one of these with a couple extra triggers
It would be cool if next months topic is 'remotely triggered off-camera flash'
Kimolaoha
Dec 5, 2020 09:32 PM
emulajavi
Dec 24, 2018 09:15 AM
seanle
Oct 7, 2015 07:43 AM
Tektura
Tires, Wheels, & Brakes
18
Sep 13, 2015 10:00 AM
caiken
Aug 27, 2015 06:55 AM
