Question about ISO.
Old Nov 1, 2005 | 08:05 AM
goaljnky's Avatar
goaljnky
Question about ISO.
This sort of relates to the post from DiD. I saw that the D200 will have the ISO all the way up to 3200. It is my understanding that the higher the ISO the grainier the picture. When the ISO is set to 400 on my Coolpix 8800 the pictures turn out too grainy for my taste. Am I doing something wrong, or is this just my "artistic preference" to have a sharper picture?
In other words, when increasing the ISO, what changes need to be made to shutter speed and aperture settings?
Old Nov 1, 2005 | 08:15 AM
francisk's Avatar
francisk
This higher ISO allow you to capture low lighting object without flash. However the draw back is the picture will be grainy. That's why in sunny day, you want something like 100ISO, indoors with flash usually use 200ISO
Old Nov 1, 2005 | 08:31 AM
racingdynamcs's Avatar
racingdynamcs
ISO200 is the lowest you really need...www.dpreview.com has tested many nikons with iso200 being the lowerst point in direct sunlight and the results are no different from using iso100 on canon's... when you have a higher ISO you can use shutter and aperture to get the best photo...the trade off is grain ...but iso100-200 you wont notice the grain at all on a SLR
NIkon's get more grain than Canon's but NIkon cameras produce sharper and Crispier images than the Canons...
Ever since I have switched to the D70 and I have never missed the lower ISO feature that I used in the past.
Old Nov 1, 2005 | 08:38 AM
francisk's Avatar
francisk
When you increase the ISO, probably you need to adjust to increase the shutter speed or increase the aperture. Since the camera is now more sensitive to light and you need to increase either one to limited the exposture.
Old Nov 1, 2005 | 08:49 AM
dave's Avatar
dave
pug poo picker-upper
Photography is light management
You manage light in three ways: ISO, Aperture, and Shutterspeed. No matter how many modes your camera has, you're fundimentally adjusting those three things.
ISO: the sensor's sensitivity to light
  • ISO 100 means it has the sensitivity dialed down, and it takes longer for each pixel to gather enough light (color information) before it knows what color to turn.
  • ISO 1600 would make the sensor 4-stops (16 times) more sensitive than ISO 100 and result in each pixel needing less exposure to light to collect enough information to determine the color it should turn
Aperture: how big the opening is in the lens
  • F/2.8 - would be a big opening for a lens, meaning it lets a lot of light in and as a result of the large opening you have a shallow depth of field (a thin focus plane). Using the lens at it's biggest aperture will result in the fastest possible shutterspeeds.
  • F/22 - would be a tiny opening in the lens, meaning light would have to bleed it's way in through the hole before it could get to the sensor. Using a small aperture also increases depth of field, so more of the image will be in focus (at F/22 all of it should be).
Shutterspeed - how long the shutter is open
  • This one is pretty self explanitory
Stops
  • Each time you double or halve the ISO, Aperture, or Shutterspeed, it's referred to as a stop. Making changes in one area necessitates changes in one or both of the others in order to maintain the same exposure.
Say you have a photo that is ISO 100, F/2.8, 1/10 shutterspeed. At 1/15th of a second you probably can't handhold the camera to take a clear shot. The Aperture can't be opened any further since we're shooting with a F/2.8 lens and it's already wide open. So, the only option here is to adjust the ISO up.
  • ISO 200 (1 stop or 2x the sensor sensitivity), F/2.8, 1/20 shutter (1 stop or 2x the shutterspeed)
  • ISO 400 (2 stops or 4x the sensor sensitivity), F/2.8, 1/40 shutter (2 stop or 4x the shutterspeed)
  • ISO 800 (3 stops or 8x the sensor sensitivity), F/2.8, 1/80 shutter (3 stop or 8x the shutterspeed)
  • ISO 1600 (4 stops or 16x the sensor sensitivity), F/2.8, 1/160 shutter (4 stops or 16x the shutterspeed)
Which do you choose? The common rule of thumb would be that you can only hand hold down to about 1/30th of a second. So we need to go to at least ISO 400 to not get camera shake to show up in the picture.
Noise
As a result of boosting the ISO to increase the shutterspeed, we also introduced more digital noise into the image. There are sofware programs that can help reduce the amount of noise, by sampling the noise in an image and then processing for it. I use Neat Image but there are other software solutions out there. Keep in mind that this will only help with the noise, it won't eliminate it. That said the results can be impressive. You will also want to do some sharpening after the noise processing otherwise the image looks a little plasticy.
Sensor Size
Sensor size does play a roll in how much noise you get.
Point and shoot cameras (P&S) have pretty small sensors, and as a result of going to more and more mega pixels, we're making each pixel smaller and smaller. Thus, just due to the size, there is less light information being used by each pixel. When you push the ISO on a P&S that further minimizes the amount of light that actually hits the sensor. As a result P&S cameras tend to get pretty noisey pretty quickly.
D-SLR's have larger sensors. They also have higher quality sensors, and aren't as susseptable to noise issues, though they certainly can produce noisy images.
Old Nov 1, 2005 | 09:47 AM
goaljnky's Avatar
goaljnky
Ok, so let me get this straight. The higher ISO numbers react faster to the light input.
Using the above explanation from DiD I could also choose to increase my ISO to 400, leave the shutter speed at 1/30, but change the apperture to something like F5.6. So let me use the bellow picture as an example:
The settings for this picture were:
ISO 100
Shutter 1/30 sec
Apperture F7.1
Since F7.1 is almost at the limit of my particular camera model, if I chose to go to ISO 200, would I than change the shutter speed to 1/60? What would be the advantages or disadvantages of doing that?
Old Nov 1, 2005 | 09:58 AM
dave's Avatar
dave
ISO 100
Shutter 1/30 sec
Apperture F7.1
Yes
In this case i wouldn't change it. From the lighting and what not, I'm guessing your camera is tripod mounted, so I wouldn't worry about it. If you got that hand held, your hands are a little more steady than mine. If there had been visible camera shake, pushing the ISO would have allowed you to get a stable picture.
The disadvantage would be more noise at higher iso.
Old Nov 1, 2005 | 10:28 AM
goaljnky's Avatar
goaljnky
Thanks for the advice Dave. Just wanted to make sure. Good eye, by the way. It was on a tripod with a coule of small hot lights.
Old Nov 1, 2005 | 11:34 AM
jwardell's Avatar
jwardell
ISO is really a film standard, and unfortunately it's been up to the manufacturer of digital cameras to loosly translate it.
All it really is to the digital camera is more amplification and different paramters for some software algorithms. ISO 200 on one digital camera does not mean it is as sharp ISO 200 on another brand's. Too bad there's no real standard for measuring this.
For example my pentax does ISO 40 but my canon is sharper at ISO 400...a lot comes down to quality of the sensor.
But their purpose is to be used as is in film cameras. Lower is sharper but needs more light. You have the option to give up sharpness for ability to capture in less light.
*and by sharpness, I mean, less grain. Not lens sharpness or resolution.
Dpreview.com is the place to go to compare varios cameras' handling of ISO and grain vs. their competitors.
Old Nov 1, 2005 | 01:27 PM
supergimp's Avatar
supergimp
(supergimp imagines Goaljnky at home playing with his pretty ponies)
Old Nov 1, 2005 | 01:59 PM
goaljnky's Avatar
goaljnky
Old Nov 2, 2005 | 12:00 AM
Deuce Coupe Effect's Avatar
Deuce Coupe Effect
From: From New Lenox, IL., but living in West Lafayette, IN.
Ugh, that triangle again. When I first learned it, it was so much more tough because with a normal SLR I couldn't just swap out my film for a different ISO between pictures. I had to work around it with my shutter speed and apature. Now with my DSLR I have so much more fun, not to mention some of the automated features. (just to note...I'm happy about the auto stuff because I came from an OLD Cannon AE-1...post-Vietnam era camera...it was my dads. So I never had anything remotely like my Olympus E-300 until recently. It made my job so much more fun when I was just wanted to take a picture)
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
