Video Camera Set Up for Track Days
Old Aug 29, 2005 | 07:08 PM
NHRef's Avatar
NHRef
Track days are incredibly exhilerating and fun in a Cooper S!
I'd like to capture the time racing around the track but don't have a video camera or a mount.
What do you recommend for a video camera? mounting system?
Thanks for your help! With luck, I'll have a system in place before the BMW CCA Oktoberfest in mid-September and will share the results.
Pete
2002 MCS (turning 75,000 this week)
R/W, Moss rally lights and bar, special side stripes
BMP air filter, Orciari hood scoops, Alta 15% reduction pulley, Alta intercooler cover, Conforti ECU reprogram - 93 octane, slotted/dimpled rotors, Goodrich braided steel brake lines, (very dirty) Mintex pads in front / Ferodo in rear, Borla exhaust, Kozei wheels with Yokohama AVS tires
H-Sport sway bars (front and rear) to be installed this weekend
Now if only the driver was up to the mods ~ but I'm learning!
Old Aug 29, 2005 | 09:11 PM
Cherry2005's Avatar
Cherry2005
https://www.northamericanmotoring.co...cat=110&page=1
Old Aug 30, 2005 | 06:02 AM
sjolly's Avatar
sjolly
I have gotten good video from this bullet camera from chasecam. www.chasecam.com Here is some video I shot with my bullet camera. https://www.northamericanmotoring.co...cat=500&page=1
Old Aug 30, 2005 | 10:43 AM
bluesmini's Avatar
bluesmini
i had a pretty good how to on mini2 about this. it cost me maybe 40 bucks and a couple hours of work.
same screen name as here.
Old Aug 30, 2005 | 10:50 AM
OctaneGuy's Avatar
OctaneGuy
Thanks Cherry2005!
Here are some sample video clips taken with the VacuCam
https://www.northamericanmotoring.co...ad.php?t=28427
and here as well
https://www.northamericanmotoring.co...ad.php?t=32936
Richard
Old Aug 30, 2005 | 06:40 PM
JaredRS's Avatar
JaredRS
Are you only considering cameras that mount outside of the car?
Old Oct 6, 2008 | 06:52 AM
gnatster's Avatar
gnatster
Dredging up an old thread here....
Since the Vacu-cam is no longer available from Richard and I'd rather not spend the grand that a Chase Cam setup costs what are people using.
Technology has advanced the past few years and I see there are cameras such as the Flip for as low as 150 bucks. I don't intend on mounting to the roll bar as I don't want the classic rear view mirror shot. I'd much rather place the camera in or around the windshield area. I was looking at the flip figuring I could use a few rubber bands to secure it to the rear view mirror.
Basically looking for a solution that will give me decent quality for at most a few hundred dollars.
Old Oct 6, 2008 | 08:24 AM
MINIdave's Avatar
MINIdave
Do you alreay have a camera?
If not, I have a Go Pro that I only used once that I would sell well within your budget, PM if interested. It has all sorts of mounting brackets and suction cups etc. Quite a few people use them as race cams, I bought two but decided I only need one.
Old Oct 6, 2008 | 08:46 AM
planecode's Avatar
planecode
A member of the Central Indiana MINI club did the following using a camera from Griots. He gets about 90 minutes per 2mb SD card. The only problem is he doesn't have a remote on off.
Old Oct 6, 2008 | 03:36 PM
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...d.php?t=145200
Old Oct 7, 2008 | 01:20 PM
MINIdave's Avatar
MINIdave
That's a GoPro camera Like I have. That's a great mount too, although I only get about 60 min on a 2 gig card. Anybody know what thread size goes in the tow hook hole?
Old Oct 7, 2008 | 01:34 PM
Motor On's Avatar
Motor On
Try searching some, but last I remember reading it was a non-standard BMW made thread size/pattern.
Old Oct 25, 2008 | 02:47 PM
OkieSnake's Avatar
OkieSnake
I use CrusieCam's mount. (Pics is from their web site www.cruisecam.com)
About $45 and works well. Quickly mounts to the headrest post. For a Video Camera, I bought a Sony Handycam that uses miniDV tapes. It was new but a return on on the clearence table at Circuit City. I paid $125 for the camera
For a link to a video I did with this set-up that I put on YouTube
Old Jan 5, 2009 | 09:10 PM
Gromit801's Avatar
Gromit801
It looks like the GoMiniGo front plate mounting hardware, with a camera mount attached instead of the plate. Nice.
Old Jan 5, 2009 | 09:53 PM
bluesmini's Avatar
bluesmini
http://www.vimeo.com/2648395
here's the same kind of camera using the suction mount
Old Jan 6, 2009 | 07:39 PM
KyleJ's Avatar
KyleJ
Actually he just cut and tapped a hole on the standard MINI tow hook to attach a custom bracket. His design inspired me to get one and do the same. The footage is much better when the camera is lower to the ground, especially with the GoPro's wide viewing angle.
Old Jan 7, 2009 | 12:23 PM
Gromit801's Avatar
Gromit801
I have a GoMiniGo front plate adapter, and it would work very well in this case. I shall have to investigate when I have a camera to use with it!.
Old Jan 8, 2009 | 08:01 AM
Bigshot's Avatar
Bigshot
What kind of resolution does this get?
Old Jan 8, 2009 | 08:04 AM
Bigshot's Avatar
Bigshot
I think there was a thread here about someone doing DIY like this.
Old Jan 8, 2009 | 09:55 AM
KyleJ's Avatar
KyleJ
512x384 video. 5 megapixel stills on the new "wide angle" version I have. 3 megapixel on his standard version. Uses 2GB SD cards. Waterproof housing. Lots of mounting options and kits.
http://www.goprocamera.com/ has sample videos.
Old Jan 8, 2009 | 09:32 PM
RockyMC40's Avatar
RockyMC40
I made one like this years ago and it worked very well. Good design and good product (friend uses one in his M). You want something solid when its in the car in the case of an accident you dont want a camera pummeling you.
Old Jan 9, 2009 | 07:48 AM
Bigshot's Avatar
Bigshot
How does this resolution look on a 1080P LCD TV when burned to a DVD (1080 up-convert DVD player)?
Old Jan 10, 2009 | 10:44 PM
Some Guy's Avatar
Some Guy
Depends on how big your TV is.
This appears to be the same thing, but it comes with a stick on mount and is only 150!
http://www.goprocamera.com/index9.htm
Otherwise they have other alternatives.
Old Jan 12, 2009 | 12:53 PM
Motor On's Avatar
Motor On
I've done it, I just found the angle boring and didn't like the implied safety risks of the fact that if used on the street for a MINI run there was a camera with a metal bar attached to the car in a place that myself and my passenger could hit there head on if moved around during some sort of collision.
But to make one it's about a total of $10 or less and you'll likely have enough spare raw materials left over that you could make another mouth for elsewhere if so desired.
Old Jan 12, 2009 | 02:31 PM
JCL_06MCS's Avatar
JCL_06MCS
check out motocam360 they have some cool camera setups. i have one that mounts behind my rearview mirror, its on youtube, search for username horse67gto
