Help. Strange pixels?
Old Jun 13, 2005 | 06:48 PM
blacknblue's Avatar
blacknblue
Photographer / Beer Dude
I've been encountering some awkward-looking horizontal lines in some of my (D70) images lately. These appear more pronounced in dark areas, regardless of lens used. What am I doing wrong?
Here is an impromptu photo I shot yesterday. The lines I'm referring to show up in the shadows of the background trees. The photograph is clickable.
Old Jun 13, 2005 | 06:52 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Juan, I'm not seeing the lines. Not in the pic as posted or when I click on it for the larger version.
Clover
Old Jun 13, 2005 | 07:09 PM
blacknblue's Avatar
blacknblue
Here's a crop from another image that has those lines.
Old Jun 13, 2005 | 07:31 PM
dave's Avatar
dave
pug poo picker-upper
I think what you're seeing is referred to as "banding". How long are the exposures? I'm guessing you're under a second from the amount of light. That seem strange to me. I have only seen that in the past on longer exposures (multiple minutes).
Old Jun 13, 2005 | 09:30 PM
blacknblue's Avatar
blacknblue
The exposures were around the 1/50 - 1/30 range on a 50mm f/1.8 lens seeing as how it was handheld, while the MINI under tree shot was more like 1/125 using 70-300mm zoom.
They do seem more like something one would encounter under long exposures. You think it might help to use that setting despite the faster shutter?
Old Jun 13, 2005 | 11:57 PM
dave's Avatar
dave
Double check the ISO. Were you at ISO 200?
Old Jun 14, 2005 | 04:18 AM
BearsMCS's Avatar
BearsMCS
Remnants of JPEG conversion, perhaps? Try RAW and see if they are still there.
Bear
Old Jun 14, 2005 | 08:31 AM
blacknblue's Avatar
blacknblue
ISO was 200.
Those bands are even in the RAW file.
Did a google search and found an article on DPReview. It discusses banding but at longer exposures. Nikonians had a post but no replies.
Old Jun 14, 2005 | 11:44 AM
jwardell's Avatar
jwardell
It's being caused by areas of bright light/overexposure. You've seen it on TV, where for example the sun or stadium lights cause those bands across the entire picture.
But I don't think your dslr should be doing that, maybe a cheap digicam, but not a D70. You may wish to contact Nikon.
Old Jun 14, 2005 | 12:14 PM
OctaneGuy's Avatar
OctaneGuy
I took the 2nd image you posted and overprocessed it in Pshp with the Levels command. I assume you are referring to this horizontal dark area?
Also I cropped out a portion of the first picture and highlighted with arrows the various dark lines. Again, I'm assuming this is what you are referring to.
I wonder if they happen in the same area of every picture or are they random? That is could you overlap 2 images of the same size and would the bands line up? Even though they may only be visible in the relative dark areas.
I would try to mock up this shot and see if I could reproduce it.
Attached Thumbnails Help. Strange pixels?-lines_d70.jpg   Help. Strange pixels?-lines2_d70.jpg
Old Jun 14, 2005 | 12:19 PM
OctaneGuy's Avatar
OctaneGuy
Found this article that seems relevant:
http://www.dcresource.com/forums/showthread.php?t=8194
They call it amplifier noise. Here's the picture thats related to that article.
Old Jun 14, 2005 | 12:45 PM
blacknblue's Avatar
blacknblue
Thanks for the article link Richard.
It appears that I'm not the only D70 user experiencing this problem.
I guess I'll have to remember to use the NR setting.
Old Jun 14, 2005 | 10:25 PM
OctaneGuy's Avatar
OctaneGuy
You're welcome. For what it's worth, my buddy was saying his friends $10K D1s exhibits this problem as well.
Richard
dinomaniac
Sep 18, 2018 04:19 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
TifosinDel
Sep 28, 2015 10:45 AM
daviday
Sep 25, 2015 01:31 AM
HogWldFLTR
Sep 20, 2015 04:48 PM
