MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Aug 21, 2007 | 10:27 AM
  #9851
1nf3rn0's Avatar
1nf3rn0
Yes. All except the one silicone intake hose....
Originally Posted by SRTech
Have you taken all the intake ducts and tubing off?
Steve
Old Aug 21, 2007 | 11:04 AM
  #9852
SRTech's Avatar
SRTech
I believe if you take that one off you can get to the side of the tube and cut the clamp.
Steve
Old Aug 21, 2007 | 11:26 AM
  #9853
1nf3rn0's Avatar
1nf3rn0
How much of a ***** is that gona be to put back on?
Steve
Old Aug 21, 2007 | 12:19 PM
  #9854
1nf3rn0's Avatar
1nf3rn0
The Nitrous install is coming along...
Old Aug 21, 2007 | 12:46 PM
  #9855
Scooby03's Avatar
Scooby03
I'm glad its you and not me.
Old Aug 21, 2007 | 01:13 PM
  #9856
1nf3rn0's Avatar
1nf3rn0
OK.... I removed the intake tube, but I still can't werstle the damn horn off.... And the clamp is rotated too far towards the intake manifold to get any kind of tool in there to remove it.....
Old Aug 21, 2007 | 01:42 PM
  #9857
SRTech's Avatar
SRTech
Cut the clamp or use a hook tool to reach around the side and pry the clamp open.
Steve
Old Aug 21, 2007 | 02:18 PM
  #9858
1nf3rn0's Avatar
1nf3rn0
I'l give that a try.... If that doesn;t work, I will bring in the heavy duty tools.....
Steve
Old Aug 21, 2007 | 02:23 PM
  #9859
SRTech's Avatar
SRTech
I'll send you my favorite.
Steve
Old Aug 21, 2007 | 02:45 PM
  #9860
1nf3rn0's Avatar
1nf3rn0
Steve
Old Aug 21, 2007 | 03:14 PM
  #9861
JIMINNI's Avatar
JIMINNI
Steve
Would that be Brad .
Old Aug 21, 2007 | 03:15 PM
  #9862
JIMINNI's Avatar
JIMINNI
Cut it with a dremel.
Old Aug 21, 2007 | 03:54 PM
  #9863
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Hey Dr.Steve,
Can we do a bracket kinda like what Blake's done (see above) since we'll be losing the Alta intake for the M7 AGS v.3? Carbon fiber would be sweet (wink, wink)
Old Aug 21, 2007 | 04:37 PM
  #9864
Scooby03's Avatar
Scooby03
Fracky,
Do you want to get the brackets done in carbon fiber?
Old Aug 21, 2007 | 04:38 PM
  #9865
riversong's Avatar
riversong
I vote for the secret tool (the sledge hammer).
Old Aug 21, 2007 | 04:40 PM
  #9866
Scooby03's Avatar
Scooby03
Are we going to use it on Blake's MINI, or Blake.
Myself, I wouldn't want to hurt the MINI.
Old Aug 21, 2007 | 05:08 PM
  #9867
riversong's Avatar
riversong
Used on either one will probably get the job done.
Old Aug 21, 2007 | 05:19 PM
  #9868
SRTech's Avatar
SRTech
Originally Posted by Fracky
Hey Dr.Steve,
Do you want me to cut the lower airbox away from the ECU box like I did on my MINI? That would leave a lot of space to play with. Carbon fiber? Do you know anybody who can fabricate the bracket for a reasonable price? How are we ever going to get your MINI smogged? Your water pump gear box on the supercharger has plenty of oil in it so that's a relief. I still don't understand where all the grease and oil is coming from. There are no leaks around the head and valve cover. Everything looks tight and it just looks like oil was spilled and left to collect dirt. I will be replacing a lot of rubber since it's pretty messed up from soaking in oil. If you were ever thinking of a head, this is the time since I am almost there already.
Steve
Old Aug 21, 2007 | 05:49 PM
  #9869
Fracky's Avatar
Fracky
Steve
Sid/Msfitoy has a picture of his engine bay somewhere where he had a small sheet of carbon fiber which provided a mounting platform for the solenoids. It covered the base area of the intake box & was approximately 6"x7" -ish. For those of us who don't know, what's a Cosworth kit run these days? My old lady will have my "you know what" on the mantle if I say yes, but I'm still curious.
Old Aug 21, 2007 | 05:59 PM
  #9870
1nf3rn0's Avatar
1nf3rn0
Horn is off, hole is drilled and threaded. Now all I have to do is wait till tomorrow to get some teflon and I will try and put it all back together....
And I tested the tubing and one of the lines has a hole in it (my entire engine bay was covered in n2o ice after I shut it off.....) so I will have to rerun the entire line that goes under my car....
Old Aug 21, 2007 | 06:00 PM
  #9871
1nf3rn0's Avatar
1nf3rn0
You are thinking of Randy at m7's car. Sid had his mounted in a similar way to mine....
Old Aug 21, 2007 | 07:26 PM
  #9872
JIMINNI's Avatar
JIMINNI
GO GO GO GO GO GO
Old Aug 21, 2007 | 07:43 PM
  #9873
JIMINNI's Avatar
JIMINNI
Hey Joe, you could just get new SSR's and get just has much speed as replacing the head .
Old Aug 21, 2007 | 08:57 PM
  #9874
ShellyQ's Avatar
ShellyQ
Just popping in to say HI to all and wanted to wish Diane(better half of PDQMINI) a HAPPY BIRTHDAY.
Nick & Shelly
Old Aug 21, 2007 | 09:12 PM
  #9875
Fracky's Avatar
Fracky
Touche! The bad part is when you're finally at the point where you can touch/taste the Cosworth but don't know if you can get at it. I'm still waiting for the cost & what my final out the door total might look like. If anyone would like to contribute their equity line to my Frackmobile project that'd be awesome!
