MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Jul 24, 2006 | 06:01 PM
  #2626
MINICHEF's Avatar
MINICHEF
JUST GOT MY DAMPER TODAY. INSTALL WILL HAVE TO BE TOMMOROW MORNING. ITS STILL 111°.
Old Jul 24, 2006 | 06:02 PM
  #2627
MINICHEF's Avatar
MINICHEF
One Fast Mini
http://www.videoegg.com/video/ehIUo
CHECK OUT THIS VIDEO OF THE M600, THAT IS ONE FAST MINI
Old Jul 24, 2006 | 06:47 PM
  #2628
MINICHEF's Avatar
MINICHEF
STEVE AND BRAD, HAVE YOU HEARD OF THIS PLACE? IT MIGHT BE A GOOD SUPPLIER FOR "THE BIZ" ESSPECIALLY FOR CUSTOM AND ONE OFFS. WHEN YOUR UP AND RUNNING I HAVE AN IDEA FOR A UNIQUE MINI PRODUST THAT SHOULD SELL VERY WELL.
http://www.keystonbros.com/frs.html
Old Jul 24, 2006 | 06:48 PM
  #2629
MINICHEF's Avatar
MINICHEF
Blake, How Was Orrientation?
Old Jul 24, 2006 | 07:11 PM
  #2630
MINICHEF's Avatar
MINICHEF
Now Thats A Blower
HEY BLAKE, THIS IS WHAT YOU NEED. IF THEY CAN MAKE IT WORK ON A JAG, THE MINI SHOULD BE A PIECE OF CAKE. MIGHT NEED A LITTLE PLUMBING WORK.
Old Jul 24, 2006 | 10:14 PM
  #2631
CruiseControl's Avatar
CruiseControl
Might need a few a-dapter kits and a HD damp'ner.
Old Jul 25, 2006 | 11:37 AM
  #2632
1nf3rn0's Avatar
1nf3rn0
Still Orienting. It's alot of fun, though. I've made alot of friends. Going to a frat party tonight all night then registering for classes first thing tomorrow. O ya, and I'm using a mac with a 30" wide screen right now. I love this school
Also, there are a bunch of hooka bars here. They rock
Old Jul 25, 2006 | 06:54 PM
  #2633
MINICHEF's Avatar
MINICHEF
Installed The Torque Damper This Morning. Found That To Install With No Binding That I Needed To Install The Short Bolt With A Close Tolerance Washer On Each Side Of The Heim Joint To Keep The Damper In A Position That Will Let It Flex And Move As Needed. When I First Installed It With No Washers It Bound Up And Allowed No Movement. The Hardest Part Of The Install Was To Get It Adjusted To The Correct Length To Fit Between The Bolt Holes. It Is Also A Knuckle Skinner To Install. Notice No Vibration At Idle And Smoothness Off The Line And Accel From Low Rpm. Have Not Had Time For A Redline Run Yet. It Is Still A Little Warm Down Here.
Old Jul 25, 2006 | 09:55 PM
  #2634
armandCooperS04's Avatar
armandCooperS04
Sounds like that damper is really worth it then. I was kind of skeptical at first but then I noticed fluid coming out of engine anti-vibration mounts.
Old Jul 26, 2006 | 12:58 PM
  #2635
Scooby03's Avatar
Scooby03
Mine showed up today
Old Jul 26, 2006 | 05:31 PM
  #2636
SRTech's Avatar
SRTech
I had the same problem and used the bell washer on the engine side. Since my engine sits higher in the engine bay then a lot of other MINIs I've seen, there was no binding on the frame side. I also drilled a hole closer to the engine and closer to the engine mount. I wonder how many people just tightened down the dampener and let it bind?
Steve
Old Jul 26, 2006 | 05:45 PM
  #2637
Scooby03's Avatar
Scooby03
I wonder if Blake survived
Old Jul 26, 2006 | 05:51 PM
  #2638
MINICHEF's Avatar
MINICHEF
If Any Club Members Would Like A Pair Of The Close Tol. Washers Please Let Me Know And I Can Bring Them To The Run On Sat.
Old Jul 26, 2006 | 05:53 PM
  #2639
Scooby03's Avatar
Scooby03
Hey its 112 outside, down a degree from the last several day. We must be on a cooling trend.
That or I looked to late.
Old Jul 26, 2006 | 06:37 PM
  #2640
SRTech's Avatar
SRTech
I'm looking forward to a cool 104° on Saturday.
Steve
Old Jul 26, 2006 | 07:17 PM
  #2641
MINICHEF's Avatar
MINICHEF
I HEARD WE WERE SUPPOSED TO DROP BELOW TRIPLE DIGITS FOR THE WEEKEND WOULD BE NICE FOR THE RUN. SO , WHERE TO GAS UP WITH 100+ TO AVOID THE PING?
Old Jul 26, 2006 | 07:49 PM
  #2642
SRTech's Avatar
SRTech
Do you have colder plugs? I have never had a problem with pinging even in the heat.
Steve
Old Jul 26, 2006 | 07:52 PM
  #2643
ATCQL's Avatar
ATCQL
Brad speaking of the heat,read in todays paper about the problem with the dairy cows.Seems your rendering plants down there can't keep up with the demand. :impatientSee you at MMTS in August.Q
Old Jul 26, 2006 | 09:01 PM
  #2644
Scooby03's Avatar
Scooby03
Glad your going to make the run. How far are you going? Tech and I are going all the way.
Old Jul 26, 2006 | 09:06 PM
  #2645
Scooby03's Avatar
Scooby03
It shows 99 for Saturday and 97 for Sunday
Old Jul 26, 2006 | 10:05 PM
  #2646
riversong's Avatar
riversong
Steve
You ready to try and put one on an auto? I'm sure it will take some ingenuity. Just think, you would be the first. Nobody is talking about how to do a MCSa. LOTF is avoiding the issue. Oh well, it will give me an excuss for not staying up with you guys. Ken
Old Jul 26, 2006 | 10:34 PM
  #2647
SRTech's Avatar
SRTech
If you don't mind a little grinding, and a new hole, I don't think it will be a problem. Most people are afraid to drill or grind, but I have done it to every vehicle I have ever owned and they have gone from 134k to 400k miles. The one with the most miles has the most holes drilled in it.
Steve
Old Jul 27, 2006 | 08:11 AM
  #2648
Scooby03's Avatar
Scooby03
Steve
I'm glad its Ken's car your drilling on and not mine.
Old Jul 27, 2006 | 08:46 AM
  #2649
SRTech's Avatar
SRTech
I already drilled holes in yours.
Steve
Old Jul 27, 2006 | 08:58 AM
  #2650
Scooby03's Avatar
Scooby03
Steve
This is true.
Took today off since all I have is the caulking left to do till next week.
Waiting for a phone call
