Mid-Ohio Motoring Club The Mid-Ohio Motoring Clubs forum. Visit our club site at www.midohiomotoring.com
Spoiler Install...
Old Feb 7, 2009 | 01:37 PM
Carve906's Avatar
Carve906
Spoiler Install...
Anyone here ever install a 'S' spoiler onto their MC(R50)? I picked one up here in the Market and now have to figure out how to ensure it stays on the boot! Just a reminder, I have the stock MC spoiler installed already, so I'm thinking it should just be a simple swap, but want to be sure before I "rip" the old one off!
Much thanks!
Last edited by Carve906; Feb 7, 2009 at 01:43 PM. Reason: Forgot there were two versions of MC's these days... :)
Old Feb 7, 2009 | 01:47 PM
D3m0N's Avatar
D3m0N
How I did it (same R50 to R53 swap)
1.) remove 2 plastic covers underneath
2.) remove 2 nuts
3.) fishing line to remove old adhesive
4.) buff and clean area under old R50 wing (it will show now with the r53 wing)
5.) 3m double stick body mastic around contact points (near nuts)
6.) carefully guide bolts through existing holes
7.) thread nuts on and tighten (not to tight as they are held in by plastic)
8.) after a few days check nuts for tight but really the mastic holds it on once it has warmed up a few times in the sun.
Old Feb 7, 2009 | 02:03 PM
Carve906's Avatar
Carve906
Wow, thanks for the quick reply!
This 3m double stick body Mastic... is this something I can pick up at the local auto store... or where?
Old Feb 7, 2009 | 02:32 PM
D3m0N's Avatar
D3m0N
I had to go to a local body shop to get it the stuff they had at auto zone was thin and you need a thicker stuff so that it makes contact
I would guess 1/8th inch thick or so
Old Feb 7, 2009 | 02:38 PM
Carve906's Avatar
Carve906
OK, I'll search around.
Thanks again.
Old Feb 10, 2009 | 06:35 AM
bad venge's Avatar
bad venge
You can also use 3M moulding Adhesive tape (it comes in a roll) and cut stripes to cover the area ....
Old Feb 10, 2009 | 07:23 AM
D3m0N's Avatar
D3m0N
I made mention in PM however I will also post here.
other notes.
1.) wait for warm day and leave in sun to get the roof nice and warm
2.) hair dryer to continue heating the old fin
3.) WD 40 melts the old adhesive very well just remember to clean it up and not leave it sit on the paint to long.
Old Feb 10, 2009 | 10:21 AM
Carve906's Avatar
Carve906
Nvm, looks like a near-by Pepboys has the double-sided foam tape in 1/2" width for pretty cheap... good deal!
Any ideas where I could get some of this? I've tried searching online and have looked at local auto stores, but not having any luck...
Old Feb 10, 2009 | 10:41 AM
D3m0N's Avatar
D3m0N
Old Feb 11, 2009 | 06:40 AM
Carve906's Avatar
Carve906
Originally Posted by D3m0N
^ heh, nice... Hadn't seen that before.
Makes sense though, was leaving the "automotive" part out my search! Thanks for the help
Old Feb 11, 2009 | 06:49 AM
bad venge's Avatar
bad venge
We have an automotive paint store that stock it... Try there ...
Old Apr 17, 2009 | 12:29 PM
gob15's Avatar
gob15
Can anyone give advice if holes need to be drilled?
Old Apr 19, 2009 | 01:06 PM
Carve906's Avatar
Carve906
it was my understanding that if you had the stock/OEM spoiler on it to begin with, that no holes would need to be drilled... but you might want to check with the dealership.
Old Apr 20, 2009 | 06:32 AM
gob15's Avatar
gob15
Actually, my Cooper had no prior spoiler on it. This will be the first. That's why I want to make sure I get the drilling right.
xSpartanCx
Dec 9, 2015 08:35 AM
jeri534
Nov 6, 2015 01:40 PM
rbarakat
Oct 3, 2015 11:08 PM
cinnabun
Sep 11, 2015 05:55 AM
minimofo
Sep 8, 2015 07:54 AM
