FS: 05 toggle switches
I installed my switch about a week ago and it looks great
I'll post pictures later!. I was wondering If any body knows if I install the rear fog program would the switch actually work!!!???
It apperar that all the wiring is there for it to work! I also welded a LED to the electric board, since I bought the switch with the clear tip. I think it was worth the trouble since it cost me about 20$ to intall everything (except for the program) Any ideas
Thanx
p.s. I have a 02 BRG/MC
Thanx
Thanx
Thanx
Will it work or not.
That thought has crossed my mind a few times. I wonder if any one has compared the old circuit board against the one that has the rear fog light switch and circuit...I have not installed the switch I bought weeks and weeks ago. Go ahead and spent the 1/2 hour labor for programing. You could put a dent in Mini Parts if it did work....Make sure you have the 3 amp diode in the 1 and 4 leads .........
Originally Posted by camelpilot
how much horsepower will it give me? will it make my car go faster?
!!! So it all depends how much power YOU want at your finger tip
The circuit boards are identical - if you add a rear fog switch, the switch will work.
BUT the LED tip will not work because that is not fitted to boards which don't have the switch - although with some skill you could add the needed surface mount parts.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
