JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Gearbox help
Old Oct 31, 2020 | 05:58 PM
Danyes's Avatar
Danyes
Gearbox help
Hi jcw crew, been a long time since I've posted. My clutch finally went out in my 2009 jcw. I am in the process of replacing the clutch with an os giken and doing a giken lsd while I'm in there. So I got the gearbox apart and the bottom shaft came out when I separated the halves. Question is, what is the best way to get this guy back in? I'm a transmission noob so forgive my ignorence, from a bit of googling it looks like maybe this is the reverse shaft? It has some what I think are synchro keys in the gear on the bottom which go into the hub sleeve. Should it take a bit of force to get the spring loaded ***** to depress? Or should the whole fork be taken out with the sleeve, put together and then dropped back in? For the life of me I can't even find an image on the web of the gear in question, all the diagrams just show the entire transmission. Thanks for any pointers!
Old Nov 1, 2020 | 05:48 AM
takrdown's Avatar
takrdown
Wish I had more advice, but I'm sure I will be doing this soon so I'm subscribing. Maybe hit up Mod Mini on Youtube if you don't hear from anyone here? That guy has saved my butt so many times with his videos.
Old Nov 1, 2020 | 07:34 AM
Danyes's Avatar
Danyes
Yeah I have watched his lsd video more than a few times. There are a few r53 gearbox tear downs out there but nothing on the r56, I have the Haynes manual and they don’t even mention anything beyond the clutch replacement. Will let you know if I figure it out.
Old Nov 1, 2020 | 01:41 PM
Danyes's Avatar
Danyes
Figured out a way to get it on. I removed the shifting mechanism and then the fork for that gear pops right out. Once out it's pretty easy to get it all back together .
Old Nov 1, 2020 | 04:50 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Ugh, I saw your first post and thought “Suck!” Glad you figured it out.
This is why I much prefer manual transmissions. With any kind of me chin cal ability, you can tear the thing down and put it right back together. No wizardry here!
1fstfiero
Jun 19, 2018 01:05 PM
proxy
Feb 1, 2017 10:34 AM
ahedau
Nov 25, 2014 07:27 AM
SuzyF
Nov 5, 2011 12:02 PM
ltjpunk7
May 28, 2007 04:26 PM
