JCW GP3 Track
Old Aug 11, 2020 | 09:51 PM
Clutch Wotan's Avatar
Clutch Wotan
GP3 Track
To start this thread, considering modifications on a GP3 the latest info is from AUTO BILD they show a video of their August Test.
This is Interesting because they have been driven out lap times on their house circuit the Sachsenring. Same driver Steve Kirsch, all kinds of F56, all interesting hatchbacks, and now the GP3.
Megane RS Trophy R 1:37:57
Seat Leon Cupra R* (2018) 1:37,63
Dynamic F56 JCW ...1:37:88
Honda Civic Type R* 1:38,17
MINI JCW GP3......... 1:38:48
Renault Mégane RS Trophy* (2019)1:38,56
VW Golf GTI Clubsport* 1:39,78
Audi RS 3 1:40,13
MINI JCW AT............ 1:45:23
Old Aug 12, 2020 | 05:03 AM
CakeEater's Avatar
CakeEater
So the GP3 did really good it looks like? .3 slower than type 3?
But way more expensive right?
Old Aug 12, 2020 | 05:47 AM
KYDan's Avatar
KYDan
Do you know what tires were on the GP3 for this run? Thanks for the video.
Old Aug 12, 2020 | 12:50 PM
TheBigNewt's Avatar
TheBigNewt
What's a "Dynamic F56 JCW" ? And is it normal for them to drive with most of the car off the track pavement on curves? I'm sure that would slow the car down right away as soon and it left the actual track pavement (sorta like a golf ball rolling from the fairway to the rough). Maybe that's why that guy in the video's time was about 15 seconds slower than the one on the list.
Old Aug 12, 2020 | 02:16 PM
KYDan's Avatar
KYDan
He may be referring to the dynamic damper option. I have it on my JCW and it is great for long road trips.
Oops, my bad, I was not following the entire thread on this topic!
Old Aug 12, 2020 | 04:18 PM
DavidPinAZ's Avatar
DavidPinAZ
It's not only normal, and not only encouraged, but it's necessary. The amount of speed you can carry through the corner by going over the berms is not insignificant. In other words, in order to control the car and stay on the pavement, you'd have to slow down more than any decrease in speed would happen by using the burms. And yes, I spelled them 2 different ways because I'm not sure which is correct, lol!
Old Aug 12, 2020 | 10:01 PM
Clutch Wotan
Autobild used the TD on their August test
They also heated the tires up front and reached via this a 4.9 instead of the factory 5,1
Old Aug 12, 2020 | 10:11 PM
Clutch Wotan
Dynamic Automotive, won the test. Fasted F56 JCW, Of course, all manual. the time of a 42.000 Euro F56 Auto stock you can see at the end )))))))
https://www.facebook.com/f56.shiva/photos/a.1569909749893124/2556385257912230/?type=3
Old Aug 13, 2020 | 11:41 AM
TheBigNewt's Avatar
TheBigNewt
https://www.facebook.com/f56.shiva/p...912230/?type=3
Gotcha. So "Dynamic JCW" is a Mini JCW modded for the track and the GP3 was stock (right?). Not sure that's comparing apples to apples but whatever.
Old Aug 13, 2020 | 08:50 PM
Clutch Wotan
Cool
A: Dynamic F56 JCW ...........1:37:88 modded MT
B : MINI JCW GP3................ 1:38:48 GP3 Stock
C: MINI F56 JCW AT............ 1:45:23. DTC Stock.
F56 Track Test 2019
Old Aug 13, 2020 | 09:21 PM
Clutch Wotan
I think this drive, including 2 high-speed safes, shows how serious Autobild is testing.
This track might be a good spot to do a countercheck!
Step one for "666" will have a tailored 3-way suspension with a high-speed rebound from.......
The setup will be for 9-inch wheels on 17" /18" complete Uniball, kicking out BMW "Screwing"
GP3 2020 front suspension !
Old Aug 14, 2020 | 02:12 AM
Clutch Wotan
This car runs in 8 weeks, like some others at the test track Sachsenring. We know the stock version did:
Honda Civic Type R.. 1:38:17
Last year the race cars were slower in wet conditions
Around 1:26:00 they go there in dry.
Old Aug 14, 2020 | 02:13 AM
Clutch Wotan
Old Aug 14, 2020 | 06:34 AM
ND40oz's Avatar
ND40oz
DTC = Dynamic Traction Control
Are you saying it had traction control off or something?
Old Aug 14, 2020 | 08:56 AM
Clutch Wotan
No thats the MINI Sport Steptronic they tested. DTC like ;-)
We will test 2 alternatives to a ASIN Stock Tune Software first and its possibilities.
Thats a reinforced Getrag, which stand`s 500 nM 24H B) Seq. 6 Speed, this transmisson you cant use in public as it works only "unter Vollast"
Stay tuned ;-)
Old Aug 14, 2020 | 09:02 AM
Clutch Wotan
Facebook Post
Old Aug 14, 2020 | 10:31 AM
ND40oz's Avatar
ND40oz
Stay tuned ;-)
DCT - Dual Clutch Transmission
DTC - Dynamic Traction Control
The JCW has either the older Aisin 6 speed automatic or the newer Aisin 8 speed automatic, not the newer 7 speed Dual Clutch Transmission that's coming in the Cooper and Cooper S.
Old Sep 4, 2020 | 11:16 PM
Clutch Wotan
2015 - 2020
310 Hp Cooper S with low drag front
2015 - 2020
Old Sep 4, 2020 | 11:17 PM
Clutch Wotan
Facebook Post
GP3 test mule
To develop a suspension the manufacturer gets the complete car with wheelsets. "235mm" seems to be the competitive size, which mounts 7.5 - 9.0 and which offset is the question. This includes of course the most important thing stabilizers.
PS ... i still want a 245 setup for a drag shootout.
Old Oct 14, 2020 | 05:41 AM
KYDan's Avatar
KYDan
I have experienced a step out from the rear with the GP3 on some tight curves repeatedly. It happens every time on the same curves which are not as tight as some others that are actually tighter. I am contemplating the possibilities of how to address this issue if possible and questioning what may be the best modification to address this issue without a major (terribly expensive) modification. Any suggestions would be greatly appreciated.
Old Nov 5, 2020 | 10:58 PM
Clutch Wotan
Yes, it's the typical MINI problem, that the rear is losing control. The original setup is too stiff. MINI suspension has zero adjustment possibilities at the rear. If you watch my videos earlier, you see 2 x highspeed safes.
Old Nov 12, 2020 | 02:35 PM
MikeMJCW's Avatar
MikeMJCW
Folks,
Does the GP3 steer any different "quicker-tighter" than a F56 JCW, does it have any body roll, understeer etc.? I have F/R sways, coilovers and a chassis brace, wondering how different a GP3 would be.
Mini of Peabody has a GP3 in stock
Old Nov 12, 2020 | 03:09 PM
KYDan's Avatar
KYDan
Originally Posted by MikeMJCW
Folks,
Does the GP3 steer any different "quicker-tighter" than a F56 JCW, does it have any body roll, understeer etc.? Yes, it seems to be quicker and tighter, with less body rolI. But, my 56 JCW is stock, so I cannot really answer your question effectively. have F/R sways, coilovers and a chassis brace, wondering how different a GP3 would be. The GP3 will be faster with the additional horsepower and less weight. See if you can get them to let you test drive the GP3. The f56 JCW is my daily and it has 280 horsepower per a dyno test, but it is nowhere close to the acceleration and speed of the GP3.
Old Nov 13, 2020 | 05:35 AM
Clutch Wotan
Old Nov 13, 2020 | 05:41 AM
KYDan's Avatar
KYDan
Is there a significant difference in the handling, and if so what does it specifically improve?
Thanks!
