F55/F56 MCS with upgraded JCW Brake
Old Apr 10, 2020 | 07:43 AM
MC485485's Avatar
MC485485
Hello. I'm F55 mcs owner and planned to upgrade JCW brake kit, so I have to upgrade 17" alloy wheels also. Is 17" 7.5J ET35 (eg. Sparco Pro Corsa) is suitable for my case? Or should I find offset range ET38 to ET40? Thanks.
Old Apr 16, 2020 | 05:59 PM
ClubsportF56S's Avatar
ClubsportF56S
ET35 is spot on
Old Apr 16, 2020 | 08:03 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's really about the spoke shape and clearance not so much the offset. As you need the spokes to come around the caliper. The only way to know is to find a JCW owner that has the wheels you want, or test fit the wheel on the brakes yourself.
When you are ready for the brakes let us know
https://www.waymotorworks.com/john-c...-cooper-s.html
Old Apr 18, 2020 | 09:55 AM
Clutch Wotan's Avatar
Clutch Wotan
Upgrade on rear for the GP3 I developed several tweaks among them upgrade on the the rear
It need 2 rotors drilled 280 mm ( 260mm Std.) due to the drills the rotor weights the same.
It uses the orignal caliper need new brackets and new brake pads
Old Apr 20, 2020 | 07:24 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Here is the write up I did on the JCW brakes - https://myredmini.com/team-dynamics-brembo-brakes/
MC485485
Apr 10, 2020 07:09 AM
dominicminicoopers
Apr 12, 2005 05:50 AM
C4
22
Nov 10, 2004 03:51 AM
Super_MINI
Tires, Wheels, & Brakes
Jun 3, 2003 11:38 AM
itsthedirtybird
Jan 2, 2003 11:44 AM
