JCW rear squeak
Old Mar 4, 2020 | 05:47 PM
madmix's Avatar
madmix
rear squeak
I installed my WMW 25MM Sway bar on Saturday. I am now getting a squeak from the right rear. Anyone else have this issue?
Old Mar 5, 2020 | 07:51 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This happens all the time when the bushings aren't greased properly or used a different grease than the one we provide. If that was done right then the noise is from something else.
Old Mar 5, 2020 | 08:20 AM
madmix's Avatar
madmix
Ok don’t have the grease you sent what kind of grease is it and I will re grease
Old Mar 5, 2020 | 08:28 AM
WayMotorWorks
Vendor
here is the correct grease as it's not common to find.
You use half the tube in one bushing and half in the other so you end up using it ALL.
https://www.waymotorworks.com/sway-b...ng-grease.html
Old Mar 5, 2020 | 10:02 AM
madmix's Avatar
madmix
Ok, thanks look like that is too small to fit in a grease gun so I guess I will have to take it apart
Old Mar 5, 2020 | 10:09 AM
madmix's Avatar
madmix
are these bushings rubber?
vodka
Suspension
24
Feb 16, 2009 09:40 AM
day96
Feb 13, 2007 09:00 PM
wonderboy
Suspension
Dec 5, 2006 02:48 AM
prolap
Suspension
19
Mar 19, 2005 07:37 AM
sunne
Suspension
May 19, 2003 08:12 PM
