F55/F56 2015 F56 JCW Starter/Ignition Failure
Old Sep 13, 2019 | 08:16 PM
F56_Rebel's Avatar
F56_Rebel
Fellow JCW mates, hoping to get some feedback on my current situation. I’ve got a 2015 F56 JCW with just 32k miles on the clock. In the past month, my car has struggled to start. Immediately putting the blame on the battery, I purchased a new OEM replacement and installed. Shortly after installing I noticed the issue was still present. I toggle the start/stop as I would normally but no crank to the engine. I get the following fault/ error on my screen (see photo attached). Typically, after a few tries the engine cranks over. Tonight my luck ran out and my car no longer starts. Had to hire a hauler to tow it home 😔. With no factory warranty left I’d like to try and diagnose the problem and potentially repair myself. I want to assume it’s the starter as stated but considering my history with mini’s it’s never what it seems. Anyone else experience this on their F56, if so, what was the cause? Please help 💔😢
Old Sep 17, 2019 | 02:15 PM
jcwminimax's Avatar
jcwminimax
Wait...why was your car towed via back wheels... ?
Old Sep 18, 2019 | 03:39 PM
TVPostSound's Avatar
TVPostSound
I was thinking the same thing.
Also MINI recommends a flatbed, not towing at all.
Old Nov 1, 2020 | 04:45 PM
Mr.JCW1974's Avatar
Mr.JCW1974
Hello. My mini Jcw has the same starting problem. Can I ask you how did you solve with your JCW? Thanks !!!!!
Old Nov 1, 2020 | 05:15 PM
sgscomps's Avatar
sgscomps
Battery has to be programmed to the car after installation, if that wasn't done that may be your problem
Old Nov 1, 2020 | 10:28 PM
F56_Rebel's Avatar
F56_Rebel
Ended up being the starter. Replaced it and turned the car in. The battery doesn’t necessarily have to be “reprogrammed” as the car was fine thereafter replacing the starter.
good luck.
USA-RET
May 2, 2019 01:24 PM
soopah256
Jul 31, 2016 09:42 AM
twentytwo
Feb 6, 2016 10:16 AM
jrs66
Jan 7, 2015 11:45 AM
wtwien
Aug 26, 2014 05:49 PM
