JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Front Aero Bumper installation question
Old Dec 3, 2018 | 12:20 PM
Ryan Hunte's Avatar
Ryan Hunte
I've just purchased a used front aero bumper and it seems the lower lip that would screw into the mounting brackets was cut off or ripped off. Will the bumper fit sturdily without the bottom being properly attached? In the picture you can see what I mean. Any alternatives to mounting the bottom part? Thanks.
Old Dec 26, 2019 | 03:33 PM
KevinR's Avatar
KevinR
When I first installed it (also used), I didn't have the lower mounting parts and the bumper moved around far too much for my liking. It's a bit hard to see in this pic, but the lip on mine is still there, but cracked.
I plan to repair the cracks and will look at adding sheet aluminum as a backing piece to hopefully give it some strength. With your lip gone, you might consider rebuilding it with sheet plastic or fiberglass.
Old Dec 26, 2019 | 05:47 PM
JackMac's Avatar
JackMac
Unfortunately the lower air dam under the Aero bumper is a weak spot. It doesn’t flex like the one on the standard bumper, so they tend to break. That air dam is functional, and helps to reduce front lift.
FYI- The lower mounting brackets are still available from MINI, at least for now.
Old Dec 31, 2019 | 08:22 AM
Yep, get them while you can, we are seeing a bunch of Gen 1 and Gen 2 MINI aero parts go NLA.
https://www.ecstuning.com/b-genuine-...r/51110397175/
Ryan Hunte
Jan 16, 2019 11:09 AM
Lazer Viking
Aug 28, 2013 06:23 PM
SNEEEZY - Erika
Apr 23, 2008 07:45 AM
pauliekeys
Jan 1, 2008 08:38 AM
SkAlex
Sep 3, 2003 05:42 PM
