JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW 2012 R58 JCW Shifting problem after manic tune
Old Mar 19, 2018 | 04:22 AM
rtorres253's Avatar
rtorres253
Hello all,
I'm having a problem shifting up while under load after manic stage 2 tune. One of two things happen, the shifter either feels heavy while engaging, or it wont go into gear at all (locked out). I've had this happen in every gear and only under heavy acceleration. I don't know if this could be self inflicted by shifting too slow or before the clutch fully disengages. Will try double clutching when I get a chance. Has anyone experience this? or does anyone have an idea of what the issue might be? Thanks in advance!
Old Mar 19, 2018 | 08:02 AM
Have an R58 JCW also, I would check the reservoir fluid and also check the slave cylinder first. If you have a leak or for some reason bled or flushed the system and still have air.
Old Mar 20, 2018 | 02:32 AM
rtorres253's Avatar
rtorres253
Thanks for the advise! The reservoir is full and I physically inspected the slave cylinder and did not show sings of leaking. Ordered some ATE brake fluid to bleed the slave cylinder...figure it wont hurt to do so.
Old Mar 21, 2018 | 12:03 PM
ok, thanks
IQRaceworks
Feb 13, 2019 08:18 AM
randeez
Apr 3, 2017 10:28 AM
BigBoost
Apr 29, 2016 10:37 PM
Jun 27, 2011 01:58 PM
HighSchoolzMINI
15
Oct 21, 2006 10:47 AM
