JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
jcw suspension modification???
Old Sep 29, 2004 | 02:14 PM
miniaq's Avatar
miniaq
i put on Haman 17x8 wheels on a 2004 works car; A) I am intrested in finding out what kind of suspension modifications are recomonded. B) is it possible to put on 225x17 tires on without having the fender rubbing on tires since i am seriously considering lowering the car most likely using Ibach lowering springs.
Old Sep 29, 2004 | 02:43 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
A JCW kit MCS is no different than any MCS. Various coli over kits and lowering springs can be used. Your wheel offset is +43mm so you can use H-sport springs or similar with 1" drop front and back and up to 215/45-17 or 215/40-17 tires without rubbing. HR springs give a bit more drop (40mm) and might rub.
I think that if you used 225/45-17 tires you would get rubbing that would require trimming.
The Hamann site recommends tires from 205/40-17 to 215/40-17 see
http://www.hamann-motorsport.de/homee.htm
Old Sep 29, 2004 | 02:50 PM
miniaq's Avatar
miniaq
which lowering springs would you recomend,,as i said i was thinking Ibach, is the sway bar a good addition?
Old Sep 29, 2004 | 05:42 PM
Wraith1416's Avatar
Wraith1416
i have the H-Sports on my 04 MCS and have been very very happy with the results. i'm using the 17-inch S-Not-So-Lites with the Eagle RS-A's. the H-sports give a good drop without being outrageous and handling that feels much more confident. i'd be very suprised if you had any rubbing issues
Teh
Aug 22, 2022 04:37 AM
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
