JCW NM 22mm rear sway bar
Old Nov 5, 2016 | 10:49 AM
  #26
Dziuna's Avatar
Dziuna
Originally Posted by GregoryK
I think the 22 solid or 25mm hollow is the # 1 best bang for your buck on this car. Especially in your case. It will transform those mountain roads. Your F56 will be less tiring to drive, more fun to drive and put a smile on your face every day. On the 22mm bar that I have on my JCW (I have 215 tires) I initially started with the low position but ultimately found that the middle position was best.
In theory the other cheap way to make the steering more neutral would be to balance up the equivalent weight of the vehicle. If you put the weight of the engine in the boot you would likely get good results....although your car would be way, way slower around the corners and up the hills!
Hi New to this site but not to Mini.
Have countryman jcw and hardtop on a boat, also JCW think it arrives following weekend.
I have almost no hills just some back roads pretty flat.
Do have DDC on it.
Which Sway Bar would u recommend?
It is also my DD
Thank you
Old Nov 5, 2016 | 02:32 PM
  #27
AtariRada's Avatar
AtariRada
My engineering brain tells me that is what is supposed to happen. The cheap way to reduce understeer is to make the back wheels less grippy. A heavy rear sway does this by restricting the travel and response speed of the suspension causing the rear of the car to "drift" more easily. This is why the higher settings cause overseer.
In theory (in my head anyway) the car will go faster around a corner with the stock bar...you will be fighting understeer the whole time however.
So...for the average guy like myself the neutral handling makes the car way more predictable and easier with the heavier than stock bar. I'm happy!
Your Engineering brain is definitely logical. I do feel like I'm faster with the sway bar vs. stock on both low and medium settings. I think the amount of suspension travel on stock height has some factor in it still. For example, last weekend I did another track day on low setting. The guy driving behind me said he saw my wheel lift up but retained some contact with the ground. On medium it's all the way off and I'm betting there is no difference at this point between medium and high setting. If I was lowered, then all 3 setting would have a different contact point (I'm speculating and will verify next year).
Old Nov 5, 2016 | 02:38 PM
  #28
AtariRada's Avatar
AtariRada
Do have DDC on it.
It is also my DD
Thank you
Definitely 25mm if you're doing the NM bar. Comes with the urethane bushing and the 22mm does not. I called NM and spoke to Jerry with the same question before pulling the trigger and he said without a doubt 25mm.
I DD on both low and medium setting and had no issue what so ever. The difference will really come out when you push your car to the limit.
Old Nov 5, 2016 | 05:43 PM
  #29
Dziuna's Avatar
Dziuna
Great Thank you
Next one will be the Piggyback.
Thinking Burger set for extra power.
But will with that one until have 1000miles and That Probably will be the hardest thing I did in a while not to review over 4k and just be gentle.
I know old days breaking period was a must not sure if it is that important this dayso but will try my best.
Thank you
JasonGSD
Suspension
Aug 29, 2016 06:01 PM
dave
Suspension
Dec 21, 2002 05:42 PM
kesh420
Dec 21, 2002 09:28 AM
KS
Dec 5, 2002 07:04 AM
rallyboy
Oct 31, 2002 07:12 PM
