JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW / GP Brake ducts
Old Jun 16, 2016 | 08:13 PM
rob76turbo's Avatar
rob76turbo
Has anyone installed and used any of of these?
http://www.georgeco.org/diy/mini-brake-duct-diy/
or
http://new.minimania.com/part/NMB400...2-53-Cooper--S
or
http://www.sneed4speed.com/mini-coop...ke-cooler-kit/
OK, I realize there is a HUGE price difference between the first on and the latter duo, but I am interested in ease of install and if they work.
Thanks in advance.
Old Jun 17, 2016 | 12:26 PM
Mini Mania's Avatar
JCW Brake Ducts
Here are the installation instructions. Pretty straightforward, and we're happy to help with any questions!
http://new.minimania.com/pdfile/NMB4000_INSTR.pdf
Old Jun 17, 2016 | 12:42 PM
rob76turbo's Avatar
rob76turbo
Thank you Mini Mania
Thanks for the feedback! I saw the web page with the install instructions. My only complaint is that it says that the wheels will not turn lock to lock in some circumstances and there may be ground clearance issues. I think of that as somewhat of a design compromise. The ducts should have been designed wider and not as deep across the lower A arm. Just saying...
What have people that bought and installed it reported back? Does it indeed restrict lock to lock wheel movement and does it scrape?
I really think this looks like the best solution with the easiest install (no cutting required...which is a good thing).
Old Jun 17, 2016 | 02:23 PM
Mini Mania's Avatar
JCW Brake Ducts
Hi Rob:
It is simple to install with only basic tools necessary.
As for the limitations, anything that hangs below the suspension reduces ground clearance. However, this should be a non-issue on the track or street, unless rallying on dirt / gravel course.
Regarding full-lock limitation - we list this as a precaution because depending on the position of the hose, the hose 'may' limit the full-lock. Since the hose can move, be routed differently, or installed in different lengths, results may vary. From our experience a few test runs to make adjustments does the trick!
Hope this helps, and please let us know if you have any other questions!
Old Jun 17, 2016 | 03:42 PM
Racingguy04's Avatar
Racingguy04
I haven't used any of them, but I've been wanting brake cooling ducts on my car for about a year. I had a track day that really cooked my brakes, and I fought brake fade all day. I think it depends on your priorities. The DIY ones are cheap and seems like they would help some. I think the sneed ones work the best since they get the cleanest air supply, but I haven't pulled the trigger on them cause I like my fog lights. I really like the mini mania ones, I hadn't seen those before, but they look like they'll do a pretty good job of cooling the brakes with no cutting of the bumper. They probably are a bit of a pain to pull the scoops off except for when you're at the track, but honestly is it a deal breaker? for me, I think it'd be worth it to not have to cut on my bumper, and swapping out ducts/fog lights doesn't sound any easier than pulling off the scoops.
Old Jun 18, 2016 | 07:28 PM
Mini Mania's Avatar
Brake Ducts
Thanks RacingGuy, we agree!
MrBlah
Sep 12, 2016 12:29 PM
rob76turbo
Jun 16, 2016 11:19 AM
Supertractor3
Jun 15, 2016 08:44 AM
willy-mini
11
Jun 12, 2016 07:57 PM
Systemlord
Jun 11, 2016 04:58 PM
