JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Coolant smell from time to time while driving.......
Old Mar 19, 2016 | 06:58 PM
dube53's Avatar
dube53
This happened the first time a couple of weeks ago and I thought it was a car I was following on the freeway. It happened again today. I am suspicious. This smell is coming in the cabin.
Is there any issues with the cooling system on the N18 engine at 16K?
Old Mar 19, 2016 | 07:03 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Assuming you are not losing coolant, watch your temperatures. At 220-230 you'll smell the coolant. No problem other than why are you getting that hot. Perhaps you should check your oil level as well.
///Rich
Old Mar 21, 2016 | 07:55 PM
dube53's Avatar
dube53
///Rich
There is no temperature gauge........ do you have one LOL.
Old Mar 22, 2016 | 08:29 AM
Hello Dube53,
The N18 has not had the thermostat housing leaks at that low mileage on the N18 , but it does happen. Have you looked at the thermostat housing under the side of the engine ? On the transmission? Is you fan running allot in cooler weather , after each shut down ?
https://www.ecstuning.com/Mini-2013-...gine/Cooling/6
[/QUOTE]
+1 thats the thermostat housing ( 11537647305 > 11538671513 now newest part number updated part ) and the bleeder screw , its tucked down in on the top of the engine and sometimes hard to see right beside the engine wire harness. Also the sensor moved a bit.
Here is a shot of the N18 engine on the side with the older design N18 thermostat, the bleeder is in the same location just shorter now. Its in between the vacuum pump and the HPFP, if you have the newer N18 3/2012+ HPFP it will be the smaller looking HPFP. Check right below this for leaks, is so contact your dealer asap.
Old Mar 22, 2016 | 08:56 AM
pfcmooney's Avatar
pfcmooney
I just did the same thing, I noticed my heater wasn't working and figured the coolant just needed to be burped. Then I was riding on the highway to work one day and my car was overheating, so I pulled over, checked the thermostat, nothing in it, but I just had an oil changed the day prior and they supposedly checked all of that. So I poured more water into the coolant, drove to the dealer and the water was gone again, but not puddles anywhere. I went home, got on here and seen where a lot of people were having the same issues, the thermostat housing was leaking but it would leak onto the top of the transmission and evaporate their. So I finally noticed that, ordered a new thermostat housing from ebay for $40, and everything is good as new. The Temp sensor it came with wasn't OEM stuff and was having issues with the computer, but I swapped the sensor out from my old one, good as new!
Old Mar 24, 2016 | 02:47 PM
jkapinos's Avatar
jkapinos
Lost my water pump at 57,000
renchjeep
Apr 28, 2026 08:55 PM
enoe01
Jul 4, 2017 08:15 AM
09OBMC
Suspension
Mar 29, 2016 05:20 AM
Gabe_R50
Mar 23, 2016 06:52 PM
zipitydooda
Mar 23, 2016 08:45 AM
