JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Spark Plug Question...
Old Sep 21, 2015 | 03:41 PM
crashd22098's Avatar
crashd22098
My current ride is a 2004 Cooper S with JCW Tuning Kit # 3387
I just bought a new MSD coil, MSD Spark Plug Wires, and NGK Iridium IX (BKR7EIX 2667) Spark Plugs from Madness Motor Works and I was assured that this set up will work fine with the JCW Tuning Kit.
My question is can I run the new set up with the NGK Iridium Spark Plugs (BKR7EIX) versus the standard NGK Spark plug that they recommend when installing the JCW Tuning Kit..... BKR7EQUP ?
I know that the MSD coil runs a higher spark or hotter, will the NGK Iridium IX (BKR7EIX 2667) Spark Plugs work with out doing any damage?
Do I just need to go back with the BKR7EQUP?
Has anyone done this set up as well? MSD coil, MSD Spark Plug Wires, and NGK Iridium IX (BKR7EIX 2667) Spark Plugs ?
Old Oct 3, 2015 | 12:30 PM
ExclusiveWorkshops's Avatar
ExclusiveWorkshops
The EIX's will be fine, they're a plug with apparently a longer service life, and on here somewhere is a chart with heat ranges I think, that shows the Iridium as a tougher material that has more resistance than copper or silver etc. I use them, not on a JCW, but with 250chp, standard coil and leads.
Old Oct 3, 2015 | 06:22 PM
crashd22098
I appreciate the feedback. I went ahead and installed the EIX's and an MSD coil/wires. I also installed a K&N air filter too. The Mini seems to be running fine, but I think I need to reset the ECU.
Reset ECU........WOW !
Old Oct 9, 2015 | 07:30 PM
Systemlord's Avatar
Systemlord
Delete
eliseo1981
May 10, 2016 05:19 AM
CRC
Sep 14, 2015 07:27 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
