JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Whine noise when accelerating in higher speeds
Old Jul 24, 2015 | 05:14 PM
AMTAG's Avatar
AMTAG
I currently own a 2011 JCW with 61k on the odo and am now getting a whine noise when it comes to letting off the clutch and accelerating at higher speeds. I am still new to this game and just need some advice as to what could be happening. Thank you in advance.
Old Jul 29, 2015 | 10:48 AM
MINI_42's Avatar
MINI_42
If it sounds like the same whine I get in mine, it's the turbo I do believe - and I like that noise! But then there are other noises that are not so nice. I once had a whine in a new Toyota, which was a front wheel bearing that went out. Can you capture the the sound on video and post it? That will help people identify it. Cheers.
Old Jul 29, 2015 | 10:49 AM
Minibeagle's Avatar
Minibeagle
Clutch slipping?
Old Aug 5, 2015 | 06:41 PM
pfcmooney's Avatar
pfcmooney
I believe it's the 6th gear in the transmission humming, at least iv noticed it too and that's what it sound like. Only does it in 6th.
Old Aug 15, 2015 | 09:55 AM
Wynnston's Avatar
Wynnston
If you're running a single mass flywheel and after market clutch then it's expected. I get it from my setup.
If it's stock then possibly something clutch/gearbox is not happy.
Old Nov 11, 2015 | 09:42 AM
dethbrd's Avatar
dethbrd
some people pay extra for that noise.... but it sounds like you dont have a sequential dog box with straight cut gears..... so your 6th gear is jacked up, or one of the bearings on that shaft, or the final drive gears, or the bearings.... hard to say without pulling it apart. but definitely got a hard part going bad.
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Marco Guardado
Sep 15, 2015 01:22 AM
xpunisherx
Aug 10, 2015 10:50 PM
