JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Oil Temps
Old Jun 12, 2015 | 10:19 PM
Wynnston's Avatar
Wynnston
Oil Temps
Hi,
I installed a P3 Gauge to monitor my temps, boost etc. and I notice that the oil temp certainly gets up there. I know these motors intentionally run hot, but I'm curious to know what's an acceptable average oil temp that you see on your JCW (if you have a gauge that is)?
Thanks in advance.
Old Jun 18, 2015 | 07:11 AM
timski's Avatar
timski
How do you like the gauge?
Does it read BMW/MINI codes or only OBD codes?
Old Jun 18, 2015 | 05:02 PM
Wynnston's Avatar
Wynnston
I didn't use it to read codes (unless you're referring to PID's). I have the Carly App and OBD dongle for that. As a gauge, it's not bad. Responsive on the rpm, speed and boost. It reads oil temp, coolant temp, boost, rpm, throttle load, speed and has a 0-100 feature. It looks ok, a retro style gauge would suit the car better for looks, but for functionality, the p3 wins.
Old Jun 19, 2015 | 07:18 AM
timski's Avatar
timski
Thanks for the response. I am pretty new to the BMW/MINI world but have
been working on cars for years. What I understand is that most off-the-shelf scanners will read all of the OBD II codes but there are many BMW/MINI codes that these scanners are unable to read because they proprietary. Haha...ok I have the Carly App on my phone but no dongle yet...I kinda forget about the app since I have never used it. So I guess a better question is does the Carly App read all of the proprietary codes that say a scanner like the Bavarian Technic reads ?
Carly's website says "factory level fault codes" so I will assume it reads everything. Any experience to what level this implies...or better put..have you pulled codes that maybe you couldn't pull with a OBD II scanner and give an example.
Also, since you have the P3 gauge and the dongle......I am guessing you have an OBD port splitter so you can use both the gauge and the dongle without having to unplug either. If you do have the splitter do you mind posting the part number and where you bought? Much appreciated.
Old Jun 23, 2015 | 03:45 AM
Wynnston's Avatar
Wynnston
I just unplug the P3 when I want to use the Carly, there is no point using both of them at once.
Old Jun 26, 2015 | 05:42 PM
blunderbird's Avatar
blunderbird
cruising on the freeway at 75mph ~235*
pulling a long hill at speed making boost ~240-250*
cruising around town and traffic ~220-225*
Not totally a JCW, but built pretty close to it. I use a ScanGauge. I was surprised just how hot the oil runs, and it probably explains why so many turbo cars that had long oil change intervals had so many engine oiling related issues.
Old Jun 26, 2015 | 06:22 PM
DneprDave's Avatar
DneprDave
I have a Marshall oil temperature gauge, it tracks the water temperature pretty closely, within five degrees.
Old Jun 26, 2015 | 07:59 PM
teamrodney's Avatar
teamrodney
I'm considering the P3 gauge to read coolant and oil but curious about your oil temp gauge. Where is the sender located please?
Old Jun 27, 2015 | 07:03 AM
DneprDave's Avatar
DneprDave
It is on the same adaptor as the oil pressure sender. On the head near the vacuum pump.
The Craven Speed adapter has multiple sensor ports I just positioned it in such a way that I could get the oil pressure, oil temperature and the OEM oil pressure sender on it at the same time. This is on an N14 engine, when they redesigned the N18 head they moved the oil pressure sender to the oil filter.
Old Jun 27, 2015 | 06:06 PM
teamrodney's Avatar
teamrodney
That is one smart move.
Old Sep 14, 2016 | 03:41 PM
isamin's Avatar
isamin
For comparison: according to my scangauge in my JCW my oil temp averages aroun 200 and I hammer this badboy all the time.
ISAMIN
Old Sep 14, 2016 | 04:43 PM
elvis cole's Avatar
elvis cole
For a good answer to the original question, Google the oil that you have in your car....you'll learn about optimum temperatures.
Kimolaoha
Jul 5, 2023 01:04 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
