JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
starting issue?
Old Jun 11, 2015 | 09:18 AM
MotoCrazy's Avatar
MotoCrazy
starting issue?
Does anyone have or know of issues relating to either the ignition switch or maybe the clutch pedal switch being intermitten? Im not sure which it is that my wife and i have to cycle in order to get our 05 JCW to start. sometimes its the key, and other times it seems like the clutch.
Old Jun 11, 2015 | 09:53 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
What exactly is going on? Have you tested all things in relation to starting issues like the battery? If you can explain a bit more of what is going on I can try to help! You can also check out our tech articles here to help diagnose the issue.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 11, 2015 | 10:20 AM
MotoCrazy's Avatar
MotoCrazy
everything appears to be normal, until it comes to actually cranking the motor. when i put the key into the cranking the motor position sometimes it doesnt act like its getting a signal to start cranking. sometimes it seems like if we just cycle the key it works like normal and cranks...other times i try cycling the clutch pedal and it works...maybe coincidence, idk though
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
Teh
Jun 13, 2018 02:59 PM
tippin
Aug 5, 2015 08:43 AM
