JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Help with 2002 solar sensor location
Old Jun 8, 2014 | 09:49 PM
Kongfish's Avatar
Kongfish
I have a 2002 JCW with the IHKA AC that I had to replace the blower motor resistor in. After pulling the whole dash and replacing it, I can't recall where the other end of the solar sensor plugs in at. I know it's located in the center of the dash, and there's a connector about 12 inches down from there but it goes under the dash through the wiring harness and I can't recall nor find the location it plugs in to on the back end. Can anyone enlighten me to the answer to this baffling question. I am one click away from completing the replacement job.
Old Jun 8, 2014 | 09:52 PM
joylove's Avatar
joylove
The solar sensor is on the top of the dash, where the sun can shine on it.
Old Jun 8, 2014 | 11:41 PM
rkw's Avatar
rkw
What I see in the wiring diagrams is that the wire from the solar sensor plugs into a connector in the vicinity of the oval vent at the top of the dash, and from there the wiring runs down to the back of the AC/heater control panel.
Old Jun 9, 2014 | 12:13 PM
Kongfish's Avatar
Kongfish
Thanks for the 411, at least I now can focus on that area looking for the plug. It doesn't go in the back of the A/C control only two plugs there. 1.) main harness, 2.) the temp sensor
If you come up with a picture of where it is plugged in at, post it. I ve been through the Bentley manual upside down and backwards three times looking for it. I ve also checked all the parts diagrams I can find with no luck.
Old Jun 9, 2014 | 01:14 PM
rkw's Avatar
rkw
This is from the BMW WDS (Wiring Diagram System, BMW's interactive "official" wiring diagrams).
http://www.bmw-planet.com/diagrams/r.../r50/index.htm
The locator images are missing on the bmw-planet.com website. I have a copy of WDS on my computer at home. For connector X18786, it brings up an image of the top of the dash. The image has an arrow pointing to the solar sensor labeled B66, and an arrow pointing to the oval vent labeled X18786. I can upload the image tonight, but isn't more specific than that.
Edit: found it on my laptop.
Old Apr 9, 2025 | 08:42 AM
greeg12's Avatar
greeg12
It sounds like you're almost done! The solar sensor typically connects to the IHKA control module or adjacent ambient light wiring hidden behind the center console, so my recommendation is to trace the wiring harness backward from the HVAC control unit.
Old May 8, 2025 | 08:17 AM
Panda23998's Avatar
Panda23998
Last edited by 2017All4; May 8, 2025 at 05:21 PM. Reason: not relevant to discussion.
Old May 8, 2025 | 01:21 PM
deepgrey's Avatar
deepgrey
These bots are really getting out of hand.
Old May 8, 2025 | 06:11 PM
2017All4's Avatar
2017All4
Super Moderator
We try to stay on top of inappropriate posts. Thanks for reporting them when you find them.
mkov608
Feb 21, 2024 02:04 PM
F5666
Electrical
Apr 20, 2023 04:43 AM
Bodacious
Jul 9, 2018 07:04 PM
IDOXLR8
Aug 15, 2011 06:29 PM
D1JL
27
Jun 14, 2005 12:36 PM
