JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW How much boost are u getting?
Old Apr 1, 2013 | 05:37 PM
leozip's Avatar
leozip
Just installed alta boost gauge the other day and recorded highest boost at 29-30 psi with all mods on my sig.my car is a factory JCW european version 211hp from factory as opposed to US 208 hp. Not sure if this make any difference at all.
Let me know your numbers as i think i have too much boost. My car runs very string though with a very aggressive tune from Evolve.
Old Apr 1, 2013 | 05:52 PM
Braminator's Avatar
Braminator
Do you have the Dyno graphs to show your numbers?
2011 JCW 280HP/308TQ
Old Apr 1, 2013 | 06:11 PM
TazMinianDevil's Avatar
TazMinianDevil
With Alta AP stage 3 tune I'm seeing 21psi. Anything over 23 on a JCW would have me double checking things.
Old Apr 1, 2013 | 07:47 PM
CarlosDMotor's Avatar
CarlosDMotor
You shouldnt have 30 psi. I hit 22 with the AP, and I was shocked at that. Just wondering: Did you follow the instructions alta gave you? Im thinking about the gauge but the install looks complicated with ripping out the center console as suggested. Also would like to know what tools were needed. Thanks
Old Apr 1, 2013 | 07:49 PM
Braminator's Avatar
Braminator
I would just like to know how he made the numbers and to see the Dyno sheet.
Old Apr 1, 2013 | 08:46 PM
Creeve's Avatar
Creeve
Boost sounds high. hp/tq numbers seem about right if they are bhp and not whp.
Old Apr 2, 2013 | 07:32 AM
leozip's Avatar
leozip
I had a mechanic help me with install which was pretty straight forwarded per ALTA instructions. It sounds high, normally is hitting 25 at high boost but twice I saw going up to 29-30 psi
Old Apr 2, 2013 | 08:05 AM
CarlosDMotor
I didn't even think the stock Turbo could hit 30psi. I can't see your mods as I'm on my phone, but 25 is alright with the proper mods and a good tune. And when do the spikes occur? Like 2k revs, or near red line?
Old Apr 2, 2013 | 06:52 PM
TerminalVelocity's Avatar
TerminalVelocity
Hitting 30 psi would have me very concerned.
Old Apr 3, 2013 | 11:31 AM
leozip's Avatar
leozip
Correct, NOT WHP. I wish...
Old Apr 3, 2013 | 11:33 AM
leozip's Avatar
leozip
third gear seems to be where I get most boost. Today I tried a vid but I hit 22-25 max. It seems like over that is when tires get loose, lost traction.
Old Apr 3, 2013 | 12:04 PM
Braminator's Avatar
Braminator
So how do you have exact HP/TQ numbers? Do you have a dyno sheet?
Old Apr 3, 2013 | 12:09 PM
TerminalVelocity
I like to see this too.
Old Apr 3, 2013 | 12:11 PM
TerminalVelocity
I'm thinking your gauge is off considerably.
Old Apr 3, 2013 | 12:22 PM
leozip's Avatar
leozip
dyno graph
Old Apr 3, 2013 | 12:24 PM
leozip's Avatar
leozip
dyno
Attached Thumbnails How much boost are u getting?-captura-de-tela-2013-04-03-s-16.23.19.jpg
Old Apr 3, 2013 | 05:38 PM
JPMM's Avatar
JPMM
with a stage one AP 21lbs tops
Old Apr 3, 2013 | 05:54 PM
george_talbot's Avatar
george_talbot
dyno
Does that dyno graph not worry you?
Was the car strapped down properly and looks like they ended the run early...
Old Apr 3, 2013 | 05:55 PM
Braminator's Avatar
Braminator
Any chance for a bigger better copy so we can see more details?
Old Apr 8, 2013 | 05:21 PM
oldbrokenwind's Avatar
oldbrokenwind
You might want to check that the turbo wastegate is functioning properly. Try connecting a vacuum pump to the diaphragm on the turbo --- engine off, and look for movement of the wastegate actuator. Not real easy to get to, but this is one cause of over boosting. You might just have a bad vacuum hose / connection --- best case. Worst case would be a broken wastegate.
A little background --- when I converted to a Garrett, I took it to Jan for a tune. Had to limp over the Sierra's because of terrible noises when boosting. Jan told me the wastegate is probably not functioning, then proceeded to explain how / why wastegates work. Turns out I had the wastegate connected wrong --- Garrett wastegate works on positive pressure, not a vacuum. Point here is my boost went ape, and with a GT28RS, that's way to much boost.
Hope your problem is as simple as a bad hose ---
Old Apr 8, 2013 | 11:04 PM
CarlosDMotor
If you hit 30 psi flooring it around 2k revs, then I can see why you are getting 30 psi. I get around 16 normally, but can hit 22psi while manually selecting gears and flooring it at low revs. Maybe try getting over boost removed on tune, or just downshift when you accelerate. Not really sure what else to say. Does the tune get rid of the boost limiter?
Old Apr 9, 2013 | 01:10 AM
TerminalVelocity
Quick question concerning your tune. Was it a dyno tune or E-tune?
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
