JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Akrapovic down pipe
Old Sep 25, 2012 | 08:05 PM
ballyrick's Avatar
ballyrick
Akrapovic down pipe
I am considering the benefits of adding the Akrapovic down pipe to my 2011 JCW 2dr. I already have had installed the basic "flash tool" tune from Revolution and the Helix intercooler upgrade.
I would appreciate you sharing any info and experience with this modification.
Will I experience noticeable additional hp and torque?
Is the installation totally straightforward, etc.
Any downside to doing this; ie; causing the check engine light to come on,
stress on the clutch, etc.
Many thanks, Ballyrick
Old Sep 25, 2012 | 08:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The Akrapovic Downpipe is a great addition to your car. We just did one on a 2011 Clubman. You will feel the torque gain after installing it. Also it makes the exhaust louder and deeper. The car we did today did not have a check engine light from the cat, we will see over time, but we do tell customers to expect one and be ready to tune it out.
Old Sep 26, 2012 | 06:40 AM
mcmmotorsports's Avatar
mcmmotorsports
Have it in 2009 JCW and love it! Had the Riss Racing first and it was a little too loud. This is juuuust right.
Old Sep 26, 2012 | 07:44 AM
laforze's Avatar
laforze
Way
Never thought to ask before, but when you do get a check engine light, does it put the car in limpmode? Or does it just throw the light?
Old Sep 26, 2012 | 07:50 AM
bmwr606's Avatar
bmwr606
Way
have you installed any milltek downpipes?
do the millteks throw a code?
from what i have read, the stock downpipe is a 400 cell cat, the milltek is a 200 cell cat and the akrapovik is a 100 cell cat
thanks
scott
Old Sep 26, 2012 | 07:56 AM
bk_mini's Avatar
bk_mini
I though all DP will throw code. unless you tune it..
Old Sep 26, 2012 | 09:18 AM
jkapinos's Avatar
jkapinos
The Akrapovic will throw a P0420 code. But the Akrapovic Delete-R will keep them at bay.
Old Sep 26, 2012 | 09:23 AM
bmwr606's Avatar
bmwr606
someone who has the delete-r posted that while the light stays off, there is still a pending code stored ... that is a fail in illinois when you go for emissions test
scott
Old Sep 26, 2012 | 09:31 AM
jkapinos's Avatar
jkapinos
scott
In the two weeks i've had it (1500 miles). I got a code once while going to redline real quick and letting off. Checked with my scangauge and had a pending code. After driving less then 20 miles, the next day it was gone and the scangauge status was ready.
Old Sep 26, 2012 | 09:34 AM
bmwr606's Avatar
bmwr606
thats encouraging ... keep us informed as you get more time/miles
scott
Old Sep 26, 2012 | 10:34 AM
ballyrick's Avatar
ballyrick
Akrapovic down pipe
I live in northern NJ and having the check engine light on is certainly
grounds for state inspection failure.
Short of restoring the car to stock prior to inspections and living with the check engine light on or a code stored the rest of the time, it seems like the down pipe installation, despite the performance benefits, is not an ideal situation, at least for me.
I presume even by adding the complete exhaust system, this will not alleviate the potential for a problem. (Assume different cat comes with the down pipe)
Any other options or suggestions on how to enhance performance, beyond the basic "flash tool" tune I have from Revolution, would certainly be appreciated.
Thanks,
Ballyrick
Old Sep 26, 2012 | 01:53 PM
WayMotorWorks
Vendor
Originally Posted by laforze
Way
NO it will not go into limp mode.
Way
thanks
scott
Yes the Milltek will throw check engine light, installed a couple.
I always advise customers that ALL brands of downpipes cause check engine lights and be prepared to deal with fixing or bypassing it.
Old Sep 26, 2012 | 02:04 PM
onefish2's Avatar
onefish2
Thanks,
Ballyrick
Since you have the RMW tune you will NOT get the CEL if you do a catless or smaller catted DP like the Akrapovic.
Since the car will not throw a CEL you will not have a problem passing a NJ inspection.
Since I know you and what you want out of the car, my advice is to just leave it alone. The stock JCW exhaust does not need replacing.
I do have the full turbo back Akarpaovic exhaust installed on my 09 JCW. If I had to do it over, I would have saved myself the time and Money and left it stock. The car is already fast enough and loud enough the way it is.
Old Sep 26, 2012 | 02:06 PM
bmwr606's Avatar
bmwr606
i am not against "fixing or bypassing it", will an ecu tune do it?
how would this be done, bearing in mind that a "pending code" is a fail in illinois, where i have to pass an emissions test?
scott
Old Sep 26, 2012 | 02:09 PM
ballyrick's Avatar
ballyrick
akrapovic down pipe
Thanks "Onefish."
TTYS....
Ballyrick
Old Sep 26, 2012 | 02:11 PM
Jack & Coke's Avatar
Jack & Coke
My friend does smog. He told me that if I install a DP my car would still pass the sniffer. It would also pass a visual inspection......unless a tech was really looking to jam you up. I would not have a CEL present on my dash thanks to my AP................BUT.............he stated that once he plugs his machine into the ODP port it would realize that I have the car tuned and it would fail based on a computer error......pretty much no real way around passing smog without swapping the DP out every time you have to do smog. At least here in CA
Doc Pain
Oct 28, 2015 07:09 PM
vetsvette
Oct 11, 2015 06:05 PM
GAT
Oct 4, 2015 07:27 PM
Nick Royer
Sep 29, 2015 03:01 PM
BossyR56
Sep 28, 2015 11:33 AM
