JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Exhaust Leak
Old Feb 27, 2011 | 07:15 AM
06mcsworks's Avatar
06mcsworks
Exhaust Leak
I noticed a sudden exhaust leak in the middle of the vehicle. Inspection revealed above a square plate, in the middle of the chassis, a bracket welded to the stainless pipe had apparently broken at the weld causing a leak. Is this event unique to me? If not, has MINI taken responsibility for the defect? I ran over nothing, no damage noted at the site.
Old Feb 27, 2011 | 12:49 PM
MINIdave's Avatar
MINIdave
If you're still under warranty they will fix it for you, otherwise just take it to a good muffler shop, they can weld it right back up for you.
Seems to only happen to JCW's. My buddies '06 did the same thing in the same place, and there have been several threads discussing this issue.
Old Feb 27, 2011 | 02:12 PM
06mcsworks's Avatar
06mcsworks
Exhaust leak continued
Thanks MINIdave. Did the previous owners with the problem attribute the weakness (in JCWs) to the fact that it's a stainless piece?
Old Feb 27, 2011 | 02:24 PM
MINIdave's Avatar
MINIdave
I don't think it had anything to do with being made out of stainless, I think it's just a weak weld somehow - they all break in the exact same place.
My buddy's car was still in warranty so they replaced his with new stuff.
Most of the other guys who's pipe broke just had it welded up, no biggie...
Old Mar 21, 2012 | 01:16 PM
krackenthorpe
Same thing happened to my JCW. I was on the extended warranty, so it was NOT covered.
Old Mar 25, 2012 | 05:14 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Everyone remember: If welding on the car, disconnect the battery first or you may fry your ECU and/or other highly sensitive electronics.
speedyg56
May 18, 2020 08:52 AM
gmonde
Sep 8, 2015 06:37 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
ASRman
Aug 13, 2015 09:33 AM
