JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Pulley swap, stock JCW, HP gains?
Old Jan 8, 2012 | 12:48 PM
brow's Avatar
brow
Hi there, although I haven't had my car for long, and I am extremely impressed with its performance, wondering about modifications already. Reading here I found that people install all sizes of reduced pulleys. My question is, what would the approx HP gains be for the more popular sizes? IE 15, 17, 19 percent? I want to keep the car as a normal daily driver, not a race car, and of course thinking about longevity would like to not "hurt" the car with any mods I do to it. My thoughts are if the 15% gives a decent gain HP-wise and doesn't affect the car too much I may go with that. Thanks for any thought or advise to a new mini owner with a massive perma-grin.....
Old Jan 8, 2012 | 04:23 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
15% is my choice for durability but you should already have a reduction pulley with the JCW, something close to 12% I believe. For a few percentage points, I don't think the gain will be worth it. Do a search on the forum and I think you'll find similar opinions.
Old Jan 9, 2012 | 10:11 AM
ZippyNH's Avatar
ZippyNH
Imo on a jcw, go stright to the 17%..as long as it fits your driving style..(non track, lower rpm streer....
the 15% will not be very noticable....
Old Jan 9, 2012 | 04:30 PM
s2k7's Avatar
s2k7
17% -- is my choice
I raced a R56 JCW yesterday, no chance! I buried him alive.
Old Jan 13, 2012 | 09:29 PM
Autobot_Lazi's Avatar
Autobot_Lazi
Until he pulls out his boost controller... then with a hit of a button...
Originally Posted by s2k7
17% -- is my choice
Old Jan 20, 2012 | 08:31 PM
terrysil's Avatar
terrysil
then you activate your N2O and watch him disappear in the rear view mirror
Old Mar 28, 2012 | 07:13 AM
astroBlackMetallic_Mini's Avatar
17% is quite an increase, but you can "re-learn" how to drive the car. The JCW pulleys are already reduced more than a stock MCS. %15 is "safe" as another put it, you may run into "issues" using a %17, I am anyway...
add more boost, and other stuff "starts to go", so possibly be prepared to replace other bits: IC boots, SC intake tube, ect.
Old Mar 28, 2012 | 07:30 AM
blue2turbo's Avatar
blue2turbo
How many miles are on your mini? if you are getting into the 60-75k range and you may have to do your crank pulley soon take that into consideration. If you go with an ATI Super Damper (highly recommended) it is about .8% larger then stock.
In my conversations with Waylen from Way motor works, I was going to order a 17% as my car is just a DD no track time and he advised that with the regular ATI Super Damper to go ahead and get a 16% pulley to keep the boost at or around 17psi. So I now run the ATI Super Damper Crank pulley and WMW 16% Supercharger pulley and the combination is awesome!
Old Mar 28, 2012 | 08:03 AM
quikmni's Avatar
quikmni
I have a JCW pulley (12%) so I went with a 2% ATI Crank Pulley because my car had 75,000 miles and I was a little worried but the stock crank pulley eventually coming apart. The combination is about equal to a 14% S/C pulley in terms of S/C RPM. I gained about 1 psi boost with the 2% crank pulley over the JCW max boost.
I am happy with the upgrade.
Also, most of the S/C pulley removal tools do not work well at removing the smaller JCW pulley so if you decide to swap the JCW pulley to a 15% or other pulley make sure you can rent/borrow a pulley removal tool for the JCW pulley.
Old Mar 28, 2012 | 09:00 AM
ThumperMCS's Avatar
ThumperMCS
It's not worth changing.
Numerous JCW's with the stock pulley making big power ~250-260whp (with head/cam/header).
Old Mar 28, 2012 | 09:32 AM
davisflyer's Avatar
davisflyer
+1
I'm on the stock pulley. IMHO, the JCW pulley is fine. Spend your money on cam and header and tune and you will be very happy!
Minibeagle
Aug 13, 2015 10:00 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
