JCW MCS vs JCW
They're not a "big deal." Cooper S has forged pistons too....same manufacturer (Mahle), same materials, just a different crown design to give the JCW motor lower compression. Everything else internally is shared Cooper S to JCW.
FWIW, I have a JCW turbo on my Cooper S and it is making more power than a tuned JCW. Works flawlessly too....considering the price difference between a JCW and S is about 7k....doing this for ~2k is quite the steal.
FWIW, I had an Alta accessport and my car ran like a raped date. My buddy got in my car and said he never felt a MINI that fast, not even a JCW car and my car doesn't even have an intake on it.........YET!
Agreed, the problem I am having, the dealer wants me to buy a new JCW in 2 weeks when they are in, but I have a $29k 08 MCS with ALL the bells and whistles. I can honestly tell you, having had a JCW over night not too long ago for a loaner, the JCW car is REALLY powerful. I mean it is sick. That being said, buy an alta accessport, get the JCW turbo upgrade (BTW Alta will offer this very soon) and a turbo back exhaust and you are out $2300-$2500, your car will be as fast as, if not faster then a JCW and you will not have to spend $35k on a new car. I am seeing JCW cars, 2009's, on here, nicely equipped for $22-24k. I couldn't bring myself to buy a new one.
The JCW is a beast next to an S.
Not an S with a JCW turbo on it, which I believe he was talking about.
Factory JCW with Alta Tune or RMW Tune is faster than a Cooper S with JCW Turbo, Alta or RMW Tune and Alta Exhaust.
Stock Factory JCW has over 50 HP more than a Cooper S from the start. Has JCW exhaust, stronger clutch, stronger internals and then you add the Alta or RMW Tune. Forget about it.
So NO, you are wrong!
And as for stronger engine internals, how many more times do I have to say this, the JCW has only a different piston CR ratio 10.0:1 the Cooper S has a piston CR ratio of 10.5:1 the pistons are made by Mahle for both models, as for the rest of the engine internals, there is no difference.
Power, sound, the wheels, the dark gauges, the Championship leather... After I drove the JCW I couldn't look back. My words in a text to my wife after I drove it were, "The JCW is evil incarnate." It made my blood run faster. I originally was getting the Eclipse Gray/Red, but the Raleigh dealership was being recalcitrant, saying they were working a deal on it, but they had PW. I looked at the pictures and said, "That looks like a race car. I'll take it."
Here are pictures of the car at its current home in Raleigh. I'll take better pictures of the car once it's in my stable.
Sweet ride! What size wheels are you running?
oh dear, your math calculation is somewhat out! BMW quote the Cooper S at 175hp and the JCW at 208hp erm that seems to be just an increase of 33hp!
That's were I got the 50 HP number from.
I also thought that the transmission has stronger internals along with the clutch?
Oh and by the way I am NOT your dear.
If they are the stock Challenge (Cross Spoke) they should be 17." I'm thinking about getting some 18'' for mine when my run flats are worn out.
Yeah, they are 17" Challenge Spoke rims in black.
7 and 8 are close together on a Droid X.
There are people here that have dynod their stock factory JCW and are pushing 200 HP to the wheels. Taking that into consideration the Factory JCW's 208 HP is under rated. If you are pushing 200 HP to the wheels, your HP is more than 208 to the crank.
Trouble now is my JCW Clubman hovers about an inch off of the pavement, I can't seem to get any traction, and it only goes wherever the wind blows...
I've got frictionless clear coat (better aerodynamics) and have replaced the air inside my tires with helium (weight-reduction measure).
193 to the wheels? On a dynojet or mustang dyno? Cause thats probably 20 more HP than most MCS dynos I've seen.
My figures were recorded on neither of your mentioned dyno's and I was and still am running nothing less than 98 RON rating fuel.
Putting a JCW turbo on an S yields higher results than you get out of the factory JCW....sorry to break it to you. I've been testing it for over a month.
Assuming its tuned correctly, the higher compression ratio in the S provides higher results.
Lol....ok then
And I can back ThumperMCS findings, as I did all this last year.
No one listens czar
No one listens czar
....But who are we to say!!!
