JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Intake Ground Wire Disconnected?
Old May 21, 2010 | 12:25 PM
Daeus
I just purchases an 05 MCS that has the JCS intake on it.
I was poking around under the hood today (the windshield squirters aren't squirting) and noticed a ground wire that just hanging out, not connected to anything.
After some research, I found that it's the ground wire for the JCW intake.
Assuming that the rest of the connections are correct (which they appear to be) I figure that it's going to either keep the flap always open or always closed.
If it's always open, then maybe it was someones way of easily disabling the flap although I would have thought they would at least wrap the connector in electrical tape so that it didn't accidentally ground.
If it's always closed...I assume that someone forgot to connect it (or forgot to reconnect it).
Can anyone confirm for sure which it is?
Thanks,
Mark
Old May 21, 2010 | 01:37 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Wiring or vacuum disconnected would result in always closed flap (assuming the flap hasn't been removed or wedged open).
Old May 23, 2010 | 07:02 PM
Daeus
Thanks Paul!
Wow..I'm speechless. It's been through 2 previous owners and has never worked correctly.
Oh well, it's been de-flapped now, so it's moot point.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
mdutton11
14
Oct 26, 2015 01:47 PM
Lt. Dan
Aug 10, 2015 12:46 PM
