JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Help! Need JCW airbox torx screw
Old Apr 17, 2010 | 06:39 PM
Gerldoc's Avatar
Gerldoc
Well, after 50K miles, I finally decided to replace my stock JCW filter with an ITG one. All went well, thanks to posts by Halifax on this forum, and Nebdingo on mini2.com...and while I had it out, I "de-flapped" the airbox.
After I finally got it wiggled into place, and got the clamp connected, etc. I went to put in the two Torx screws....and , one of them , fell down into the depths of the car. Try as I might, I could not locate it, nor could I get it to fall out by moving it and hitting the brakes, etc. of course, it will probably fall out on the highway somewhere.
Any ideas on where I can get one of these? I have the other installed, and it seems to be holding everything together OK, but I want the other one in, too.
Thanks!
Old Apr 17, 2010 | 07:03 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If you are referring to the two screws in the front of the box that secures it to the lower section, I would just remove the one you have and take it into any hardware store and find a replacement.
I have one like that as well.
Old Apr 17, 2010 | 08:39 PM
FlzRider's Avatar
FlzRider
http://www.realoem.com/bmw/showparts...70&hg=13&fg=20
It is part 6 in that diagram. The part number is 13721488796. Any MINI dealer get it for you.
By the way, I really hate how all the individual parts for anything JCW related are so ridiculously expensive.
Old May 30, 2010 | 07:03 AM
davisflyer's Avatar
davisflyer
I have replaced both of mine with Philips head screws.
Old May 30, 2010 | 11:24 AM
Gerldoc's Avatar
Gerldoc
I finally took one of the other airbox screws down to my local ACE hardware store (the kind that's like one of the old-time hardware stores, with everything you could ever imagine stocked on the shelves, and then some!)
Picked up a close-enough screw and it worked perfectly!
alistaircookie
Oct 8, 2015 10:52 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
replacement
Aug 19, 2015 08:46 AM
Herleman
Aug 16, 2015 06:41 PM
minipopkart
Aug 13, 2015 05:22 AM
