JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
how i know if it is a JCW?
Old Mar 6, 2010 | 03:24 PM
carlitosway's Avatar
carlitosway
Hi all,
how i know if this car has the jcw kit?
History:
I bought a 2003 mini cooper s with 67000 and i noticed that it had the jcw badges front and back:under the hood has the intake with serial number and the inter-cooler cover with jcw logo,back exhaust with tips except the air box!!
Today, I was replacing the sparkplugs and i noticed that it has the plugs for the MCS but not the jcw.
What happens if i used the jcw sparkplugs? Can i damaged something?
thanks for you help in advance.
Old Mar 6, 2010 | 05:06 PM
GBMINI's Avatar
GBMINI
If you have a JCW serial number, it's pretty likely you have the kit. You should also have a sheet of paper - certificate - with the same serial number.
Apparently, using the wrong spark plugs left the engine running OK - but it's best to use what's spec'ed.
Old Mar 6, 2010 | 06:31 PM
carlitosway
Thanks for the reply.
I bought the car from a small private dealer and i don't have the certificate. Also, i just when to my bmw and they have not records of the jcw kit installed by the dealer.
Do you thinlk I can trace the jcw kit with the serial number?
Old Mar 6, 2010 | 06:38 PM
GBMINI's Avatar
GBMINI
Don't know if there's a central database; MINI USA might be able to help
Old Mar 6, 2010 | 07:02 PM
carlitosway
thanks i will check.
Old Mar 7, 2010 | 12:20 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Sounds like JCW
Check to see if you got 380 injectors.
Old Mar 7, 2010 | 11:10 PM
carlitosway
How do you check that?
I think the intercooler is in the way to look at them.
thanks for the advice.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
