JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW springs with CooperS stock suspension
Old Sep 12, 2008 | 08:27 PM
minimust's Avatar
minimust
I know that JCW springs can be purchased as a stand-alone item. I know that a VIN must be given when ordering, so that springs appropriate for that particular car's suspension can be supplied. But, as simple a question as it may be, what I can't get clear on is this: is there a JCW spring which is appropriate for, and can be purchased for, use with a CooperS stock suspension? Such an arrangement would pretty obviously be for someone who wants to stick with MINI parts and could be happy with the minimal drop of JCW springs.
If anyone has a minute to answer this, I'd be most appreciative!
Old Sep 12, 2008 | 11:37 PM
Derosi's Avatar
Derosi
The Springs are not designed for stock struts
All JCW springs are designed for the JCW Strut. You can install just the springs but don't expect a performance increase as the strut and spring were designed to work together. It will lower your car almost 4 tenths of an inch. People will say lower is better but if you are not going to get struts I would suggest a progressive rate spring like the Eibach.
Old Sep 16, 2008 | 09:55 AM
orangecrush's Avatar
orangecrush
I did install the JCW springs without the JCW struts. I do have the sport suspension and the handling has definitely improved. (I also added a 22mm rear swaybar).
For a few track days and a daily driver, I would recommend it.
If you plan on doing a LOT of autoxcross or track days, I would go for the whole setup or as Derosi said, go aftermarket.
HTH's,
Mark
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ASRman
Aug 13, 2015 09:33 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
