JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Inlet Tube Install
Old May 10, 2009 | 01:31 PM
  #26
Pocket_Rocket's Avatar
Pocket_Rocket
Can someone explain what the purpose of this mod is? What does it do exactly? Is it for factory JCW or Tuning Kit or both?
Sorry.. just ordered my JCW so just trying to understand what the flaw with the stock design is and why this is better..
Thanks!
Old May 10, 2009 | 01:35 PM
  #27
iwashmycar's Avatar
iwashmycar
its an upgrade compared to our stock S tube. The JCW should have it already if i understand correctly
Old May 10, 2009 | 03:03 PM
  #28
Rixter's Avatar
Rixter
Thanks!
I'd have to defer this question to somebody like OrangeCrush who actually knows what they're talking about.
Old May 10, 2009 | 05:01 PM
  #29
oldcracker's Avatar
oldcracker
how much was the part?
Old May 10, 2009 | 10:00 PM
  #30
Rixter's Avatar
Rixter
I sent you a PM
Old Jun 19, 2009 | 10:30 PM
  #31
Rixter's Avatar
Rixter
So I stuck on the new inlet tube. I noticed that it didn't come with any rubber sleeves, as shown in the 2nd picture in the initial post. For those who ordered the same thing, did it come with 2 rubber inserts?
Old Jun 19, 2009 | 11:10 PM
  #32
thevelourfog's Avatar
thevelourfog
It only comes with one sleeve which you don't really need anyways since it's too big. The other sleeve in the pic is from the stock tube which you swap over to the new tube.
Old Jun 20, 2009 | 12:10 AM
  #33
Rixter's Avatar
Rixter
Ok I think I'm getting this sorted out. The new Inlet Tube came with one rubber sleeve, it was attached at the narrower end of the tube, away from the CAI. I can either use the rubber sleeve that came with the tube or use the original one. At the other end of the tube, closest to the CAI, it doesn't require a sleeve.
Correct ???
Old Jun 20, 2009 | 08:19 AM
  #34
thevelourfog
Correct ???
Correct, there is one sleeve on the tube on the turbo side (Better to use the original one). There is no spacer on the MAF side.
Old Jun 20, 2009 | 09:38 AM
  #35
Rixter's Avatar
Rixter
Thanks much your help! What's a MAF by the way? 'Main Air Filter' or 'Marc Andrea Fleury' of the Pittsburgh Penguins?
Old Jun 20, 2009 | 01:38 PM
  #36
iwashmycar's Avatar
iwashmycar
Mass Air Flow sensor... the big thing inbetween the tube and the airbox. has a harness plugged into it
Old Jun 20, 2009 | 05:41 PM
  #37
orangecrush's Avatar
orangecrush
Thanks!
The stock MCS tube is a little soft. The JCW is much more rigid which overts any possibility of collapsing.
If I remember correctly, I think the JCW tube may be a little larger diameter... Someone perhaps can verify this....
Mark
Old Jun 30, 2009 | 10:40 PM
  #38
Rixter's Avatar
Rixter
I noticed that it's also ever so slightly shorter, but it's also straighter, if that makes sense. In other words a more direct flow. Truth be told though, I never got out the tape measure to compare
squawSkiBum
Oct 2, 2015 09:21 AM
Da_jesus
Aug 25, 2015 04:20 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
