JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Mods
  #76
Old 02-10-2008, 12:24 PM
OldRick's Avatar
OldRick
OldRick is offline
Any work on the head will completely blow the engine warranty, for sure. The pulley (and plugs), at least, is not going to realistically affect the warranty on anything but the supercharger.
Forget the bloody injectors for now. Your next engine upgrade after CAI and pulley (and plugs) should be an ECU (non-JCW) remap.
However, I also agree with others who recommend a rear sway bar for the next, most cost-effective upgrade. (And don't even Think about a front swaybar)
  #77
Old 02-10-2008, 12:29 PM
minimarks's Avatar
minimarks
minimarks is offline
Agree, free flowing head is one of my next mods, but to get the most out of it you would want better exhaust. JCW flash recognizes the larger injectors and for me it works very well for a $100.00, UNTIL I can get to a Jan tune.
  #78
HighLife4136's Avatar
HighLife4136
HighLife4136 is offline
Speaking of plugs, make sure and torque them properly or that "blow" the warranty too
  #79
Old 02-10-2008, 12:32 PM
Handsome Rob's Avatar
Handsome Rob
Handsome Rob is offline
is there any particular plugs that you recommend? what about recommendations on a rear sway bar? i do mainly in town driving. what about a front underside brace like the mini-madness?
  #80
Old 02-10-2008, 12:38 PM
HighLife4136
I wouldn't change them at all unless you find a need...if you experience any pinging...which btw, if you do and the engine were to blow, the dealer might decide to deny warranty due to the pulley causing higher temps. I'm not trying to scare you as I have never heard of this happening with just the addition of the reduction pulley, but just throwing out a scenario of what dealer could do if something happened and they/MINI USA wanted to deny warranty coverage. If you're gonna mod, then do it. If you're not, then get a cupholder
  #81
Old 02-10-2008, 12:42 PM
HighLife4136
Read this on the swaybar: http://www.northamericanmotoring.com/forums/showthread.php?t=128161
It's one of the shorter threads with little to no BS
  #82
Old 02-10-2008, 12:43 PM
Handsome Rob
ok, so no injectors, plugs, wires, or coil pack. just exhaust, pulley, cai, and rear sway bar. what about the gp intercooler that im looking for?
  #83
Old 02-10-2008, 12:49 PM
HighLife4136
If you think it's worth $700-800 and you're having issues with cooling then get it. Again, you're not going to get huge gains with it and you're not tracking the car (I think?), so I'd put that money to something else like lighter wheels and sticky tires.
*You might want to ask around and make sure it will fit an auto tranny car...I'd think it would, but some of the aftermarket coolers don't due to the auto's engine setting a little higher.
  #84
Old 02-10-2008, 12:58 PM
IamSMC's Avatar
IamSMC
IamSMC is offline
Originally Posted by msjulie33
Just curious - how much hp can an auto MINI take, vs the 6 speed?
https://www.northamericanmotoring.co...igh+horsepower
  #85
Old 02-10-2008, 01:32 PM
Handsome Rob
which rear sway bar would you recommend? would you also recommend a front underside brace? i would also like to do the JCW suspension sometime soon.
  #86
Old 02-10-2008, 02:27 PM
Marwan's Avatar
Marwan
Marwan is offline
Originally Posted by shooler
Not necessarily true. My local dealer will sell me JCW injectors all day long, but not the software (). It's ok though.
My dear, the ECU remap is just few commands that need to be applied to the same stock software, no changes or reloading. Those commands come on one of the installation instructions. I can send you the instructions as a PDF if you want.
  #87
Old 02-10-2008, 05:41 PM
Handsome Rob
what would i need to perform the remap?
  #88
Old 02-10-2008, 06:05 PM
suss1173's Avatar
suss1173
suss1173 is offline
Morristown Mini (in N.J.) has the JCW exhaust for $675. However, I dont think JCW exhaust is going to do much with out CAI, ECU, and Injectors and after that expence you will probably say you wish you spent 1/2 the money and just went with the pully. Moristown Mini has the CAI, and Injectors for $440.
This is comming from someone that just did the JCW exhaust....
  #89
Old 02-10-2008, 06:10 PM
Handsome Rob
i have the jcw cai, i have the pulley on order, and i have been told in previous replies that the injectors are a waste of money. that is why im so confused.
  #90
Old 02-10-2008, 06:31 PM
Handsome Rob
i now have the opportunity to purchase the gp intercooler. what are ppls thoughts on this? if i already have the jcw cai, soon to have the pulley, get the gp i/c, then the jcw exhaust, and finally the jcw injectors w/ software is that going to work or be a problem?
  #91
Old 02-10-2008, 06:40 PM
Maxicooper's Avatar
Maxicooper
Maxicooper is offline
With the set up you've mentioned above, it will work just fine.
Basically, it is a JCW kit w/o cylinder head and with a smaller pulley. If you don't want to go extreme, you will have fun with the set up.
Once you settle with your hardware mod, then it's time for a fine-tuning. Have a custom-tuned to make the hardwares work together in harmony and fit your driving style.
It's all about fun, isn't it?
  #92
Old 02-10-2008, 06:46 PM
Handsome Rob
where in the world would i be able to get it custom-tuned? i live in nebraska. there really isnt any custom shops around unless i go to kansas city. what hardware mod would you suggest?
  #93
Old 02-10-2008, 06:47 PM
Handsome Rob
and yes it IS suppose to be fun!!!
  #94
HighLife4136
Not a waste of $$$, just an unneeded expenditure for where you're at. With the JCW tune and injectors with 15% pulley I was running a 10.6 AFR...riiiich. With the regular tune and no JCW injectors, I was running a 10.8 AFR...riiich.
  #95
Old 02-10-2008, 06:50 PM
//MZero's Avatar
//MZero
//MZero is offline
I have only been a Mini owner for a few weeks now but personally I think the stock intercooler in this car is quite pathetic and hardly does anything. I'm not a noob to cars, or to F/I either. I dont see a huge problem with the size of the intercooler, but rather the fact that air can't actually flow through it, and that you need to be moving at quite a high speed to shove enough air at it to actually cool it down. I don't think the gp intercooler serve any better. I do think that it would help slow the amount of time before it becomes heatsoaked...but it'll still heatsoak and once it does, it'll take a while to get it back.
Keep in mind, intercoolers do not "add" hp, they simply keep the air cooler which prevents hp loss. And the most important function of the intercooler is that it wont get heatsoaked when you are actually asking it to work for you. The only way you "gain" or "loose" hp with an IC is pressure drop or lack thereof.
The best intercooler designs I have seen thus far for the mini are the M7 DFIC and Alta's version of that. I also like the water/air but it is a lot more work/weight...and if you have the proper air/air design then that would be the better way to do it. Less stuff to go wrong, less weight...and all you need is air. So IMHO, I wouldn't bother with the GP intercooler.
As for the rest of your plan, of course its going to work. Everybody is just telling you that you can do things cheaper and more efficently. But if you want to stick to JCW, thats fine. You just don't get the same bang 4 buck.
  #96
Old 02-10-2008, 07:06 PM
Maxicooper's Avatar
Maxicooper
Sorry, I forget that you live in NE.
  #97
Old 02-10-2008, 07:08 PM
Handsome Rob
what about "where i want to go?" i have posted what i want to do.
i have the jcw cai, i will have the 15%, i can get the gp intercooler, then the jcw exhaust, and finally the jcw injectors w/ software. followed by the jcw suspension, and possibly a 19mm rear sway bar.
  #98
Old 02-10-2008, 07:17 PM
tazio's Avatar
tazio
tazio is offline
The GP does hang a couple of rows off the back, where air can actually flow through. Not saying it will make much of a difference, just keeping it real.
  #99
Old 02-10-2008, 07:20 PM
Handsome Rob
we dont have anything here but cows and farmland. im still trying to find a good motoring road. I-80 is a long interstate of nothingness.
  #100
Old 02-10-2008, 07:39 PM
minimarks's Avatar
minimarks
#1 Fun, reliable and efficient!
Quick Reply: JCW Mods
