JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Kit is in!!!!!!!
Old Jun 10, 2003 | 09:47 PM
  #26
carman's Avatar
carman
IS IT WORTH THE MONEY? TELL ME TELL ME
Old Jun 12, 2003 | 06:26 AM
  #27
CooperSdriver's Avatar
CooperSdriver
I enjoyed it alot. You definitely feel the midrange power. and the car does get a little louder but I still think that they did a great job with it. On the highway I felt as is I was in a lower gear the whole time, its just to much fun. It is a very fun car.
Old Jun 12, 2003 | 06:28 AM
  #28
koolmini's Avatar
koolmini
>> ... no brakes ... (read Randy's thread about that oversite!) ...
5 million dollars and NO BRAKES ???????
for that kind of Scratch ($$$) you think they would upgrade the brakes
you can go really fast, but you can't stop it
_________________
Old Jun 12, 2003 | 06:38 AM
  #29
CooperSdriver
I understand what you are saying, but I really don't feel the need for the brake upgrade, even though it would be nice to have. I would definitely have a brake upgrade kit if it were my car.
Old Jun 12, 2003 | 06:50 AM
  #30
gmack's Avatar
gmack
>>sweet so that means i can get a pulley for my MINI and still be under warranty!!!
I thought I read that the entire blower was replaced with one that had ceramic coating on key parts for better sealing and heat disipation. $4500 would seem realy steep for just a pulley, head,ecu and exhaust wouldn't it ??
Old Jun 12, 2003 | 09:24 AM
  #31
SCA's Avatar
SCA
>>_________________
So you're going 100 mph in the stock S or 100 mph in the JCW S. And you have to stop quickly. Why does the JCW S suddenly need a brake upgrade? Does it not stop as fast as the stock S? Is it heavier or something?? Please help me understand.
Not that I'm against a brake upgrade in EITHER case, but why is it so much more important for the JCW S?
Old Jun 12, 2003 | 09:27 AM
  #32
SCA's Avatar
SCA
Yes, it is an entirely new blower, with a different coating on the vanes to reduce leakage and improve boost. Has a smaller pulley too but not sure if it is the 15% reduction that other pulleys are.
Old Jun 12, 2003 | 09:28 AM
  #33
dave's Avatar
dave
pug poo picker-upper
I think the point of the brake comment is this:
the JCW kit only addresses the engine. It doesn't make any changes to the springs, shocks, swaybars, brakes, wheels, or tires. There isn't a limited slip either.
Old Jun 12, 2003 | 09:32 AM
  #34
koolmini's Avatar
koolmini
_______>>
i see your point and you are correct,
which is why a brake upgrade is on my to-do list (i drive too fast)
but for the $$$$ i think a little extra stopping power would be nice, it would also justfiy the price alittle, other then saying that the JCW kit is covered by warrety
just my opion
  #35
dominicminicoopers's Avatar
dominicminicoopers
Hmmm...interesting questions...
I think better brakes comes from a racing mentality. Say you have a straightaway between two very sharp corners. You take the MCS down it at WOT and you get to 70 MPH and then have top brake hard for the corner. All's OK, but just barely. Now you have the MCS-JCW barreling down that same straighaway at 100 MPH (due to more HP/torque), those same brakes that barely slowed you down enough to make that sharp corner with a stock MCS are not going to be enough to slow you down from 100MPH. See?
Old Jun 12, 2003 | 09:36 AM
  #36
dave's Avatar
dave
Well, it is new, but it isn't different.
The Stock Cooper S has a 5th generation M45 Eaton supercharger and has a ceramic coating.
The JCW supercharger is effectively ONLY a reduction pulley
Old Jun 12, 2003 | 09:56 AM
  #37
SCA's Avatar
SCA
Good answer, and you have a point there with that example. No doubt it would be nice to get a brake upgrade as part of the kit for the same price, but unfortunately it ain't happenin'!
Old Jun 12, 2003 | 06:42 PM
  #38
Diggy's Avatar
Diggy
OK, got mine back today, drove it 40-50 miles, car only has 277mi on it so not WFO until break-in. I also have LS header, still waiting on Madness airbox, big TB. H-sport springs, madness bar, 215/45 ES100's, SSR Comps are on.
In a word, AMAZING. It'll leave a stop sign at idle, no bog, no nothing. Midrange is fat, I ran stock MCS(broken in) and left 'em in 2nd, waay back in 3rd, despite not pounding it too hard for break in. I also looked at Gen 5 blower next to my works, and they are different coatings, the Works is darker, looks, feels different. Magic dust? WFK I think Randy's packages are great, and well priced, as are some others, but if you can afford it, do it.
I put 7k miles on my old MCS, and never used up the brakes. If you track it, you may need more, but I'd swap pads 1st, rotors too before whining about stock brakes. Nurburgring testing thought they were okay, or BMW/Mini would have done something.
Gonna be hard to be good for another 923miles of break in.
Old Jun 12, 2003 | 06:46 PM
  #39
mightyMiniz's Avatar
mightyMiniz
THE JCW Kit NEEDS a BRAKE UPGRADE.... The Stock Brakes are fit to the engine spec.... not the JCW spec.
Look at the Infinity G35-(basically the slick 350Z) - It has Stock Brembos....Good Move
Old Jun 12, 2003 | 06:54 PM
  #40
Diggy's Avatar
Diggy
Ummm, Mini tested the JCW at the 'Ring for 80,000km. Thats why you have the overpriced warranty, laps ain't cheap. Again, they used stock brakes, did not see problem with them, or they would change them. Same deal with M cars...I have a 32k mile M5 finishing third set of tires, original pads/rotors. I put 230 miles on it today at or above 100, and no brake fade. Same trip in next couple days with works, and I expect same.
Be like me...don't use brakes!
Old Jun 12, 2003 | 06:57 PM
  #41
Hank's Avatar
Hank
CooperSdriver, what dealership are you associated with?
Engineering wise the brakes on the car are more than adequate even with the engine upgrade. The only time you will ever need beefier brakes is if you take it out on the track.
Old Jun 12, 2003 | 07:54 PM
  #42
Daytona955i's Avatar
Daytona955i
Sure the brakes will stop eventually but they are way too mushy for me.
SS lines, new pads, slotted rotors and new fluid are on my list of upgrades and all I have is the 15% reduction pulley. (more planned as budget allows)
When I need to stop I want to *STOP*... not slow down to a stop. The stock brakes are mushy and on par for most stock cars. But from a performance standpoint (something the JCW package is supposed to be) I want better brakes.
-Chris
Old Jun 12, 2003 | 08:07 PM
  #43
gosharks's Avatar
gosharks
I saw the JCW kit at MINI of Mt. View (California) today. $4500 plus $1700 installation! They were trying to justify the cost saying that a supercharger for a Honda from Jackson Racing would cost you $5k to install. I said "whatever and added, when you start adding this kind of money to a loaded MCS, you are in the same league moneywise as a 350Z." Not my cup of tea because I love my MCS, but this is only a good alternative to those with ample means and budget for cars. I am going the MINI Motorsports direction and the money saved can help go for brake pads, rotors, and even upgraded tires when needed. For those going for it, you are going to get a great package with the peace of mind of maintaining your warranty. You will truly have something we will all be a bit envious for.
I asked if they would sell the exhaust seperately and they said they would not. Nice looking unit, I wish I could figure out who makes this system for JCW.
Old Jun 12, 2003 | 08:53 PM
  #44
Diggy's Avatar
Diggy
Sharks, I heard that they may offer the exhaust later. It sounds great, I had the owner of the dealer drive by while on it pretty hard...growls, no resonance I have found yet. One clamp may be a problem, but nada so far.
Old Jun 12, 2003 | 09:51 PM
  #45
Sleepless's Avatar
Sleepless
The MCS brakes feel pretty much the same with all those mods...
Old Jun 13, 2003 | 07:19 PM
  #46
Daytona955i
I really doubt that as what brake pads you choose make a HUGE difference. I agree that there is some debate over SS Lines but I've noticed a difference in my motorcycles so I hope to see similar differences in my car. Maybe you drive with wooden blocks on your feet.
-Chris
Old Jun 14, 2003 | 07:43 AM
  #47
OpusMini's Avatar
OpusMini
I don't know what the uproar over the lack of a break upgrade is about. I mean, I'm sure that everyone who put the pulley on their car immediately put an upgraded brake package on too, right?
It almost sounds like any mechanic letting a pulley'd Mini out of the shop without upgraded brakes is committing an act of grave irresponsibility, possibly even malfeasance. Shouldn't aftermarket suppliers require proof of an upgraded brake package before even selling a pulley to a customer?
At least, there should be a disclaimer so that the customer realizes that they're driving a car that only has 10.9" ventilated front disc brakes, usually sitting on 17" rims with 7" wide tires to stop a 2,700 lb hatcback.
Come on, guys. It would be nice if Mini built the perfect high performance car, but then what would there be left for people to upgrade and talk about?
The only area where I get the sense that Mini really missed the ball was not including a limited slip. All the reports from the track seem to indicate that it was a glaring omission.
Aug 19, 2015 08:27 AM
Aug 19, 2015 08:22 AM
