Interior/Exterior Racing seats and harness "idiot light" problems
Old Apr 2, 2007 | 04:39 PM
pberd's Avatar
pberd
Hi all;
I installed 2 new corbeau racing seats and harnesses that look great but created a problem. The passenger seat airbag system believes there is a less than 20lb. person in the seat and therefore has disarmed the bag. Does anyone know how to "fool" the system so it re-arms and protects my passenger in a collision. Also the racing harness replaced the stock belt system and now I am plaqued with flashing idiot lights and warning bells. How do I override or fool this car that is apparently smarter than I am. Thanks for any help.
Old Apr 2, 2007 | 05:27 PM
mylittlemini's Avatar
mylittlemini
i remember an old thread on here about splicing wires together in the seat belt latch/catch thingy to turn off the belt light in the dash. for the air bag i know on some vehicals the weight sensors are attached to the seat where the the frame attaches to the track, look like little boxes sitting onto of a small shaft, and others ive seen are in the cushion itself. if you have a wiring diagram look for the signal wire from the pass. seat to the air bag control module. usually the signal wire either sends a ground signal or like a 5 volt reference to signal the module to activate the bag. i dont know how MINI does it but thats what i have found from the vehicals is work on.
Old Apr 2, 2007 | 05:31 PM
mylittlemini
heres the thread. is for the seat belt chime bt usually the chime and the light coinside with each other.
https://www.northamericanmotoring.co...ad.php?t=57059
hope it helps
Old Apr 2, 2007 | 06:41 PM
1nf3rn0's Avatar
1nf3rn0
Good thread. Thanks!
Does anybody know how to fool the passenger seat weight sensor though?
hope it helps
Old Apr 3, 2007 | 04:08 PM
mylittlemini
from what i have found on realoem it appears the weight sensor is a mat that is between the bottom seat cushion cover and the cushion itself. unless you can find a way to mount that mat on your new seats, i dont know if youll be able to reactivate it. from what i can guess the air bag module is sensing a resistance change through the mat to measure the amout of weight in the seat. and if thats how it works then you could possibly place a resistor with the proper amount of resistance in the circuit and fool the computer to think that it is loaded with enough weight to activate the bag.
Heres a link to the part im talking about. its the coil mat thingy in the middle.
http://realoem.com/bmw/showparts.do?...81&hg=52&fg=10
Old Apr 3, 2007 | 04:35 PM
1nf3rn0's Avatar
1nf3rn0
Actually, it would be fairly easy to mount that under the cussion with the Sparco Fighters I have... Thanks for the link!
Old Apr 3, 2007 | 07:22 PM
mylittlemini
no problem. i know how annoying those idiot lights can be.
hope it all works out. good luck.
W0TM8
Dec 19, 2019 07:50 AM
Zettinger
Aug 25, 2015 04:04 PM
JaysinStrife
11
Aug 13, 2015 04:33 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
