Interior/Exterior Does The Roof Bolt-On?
Old May 5, 2003 | 03:09 PM
res0zvle's Avatar
res0zvle
Well, after 400 miles my MCS was hammered by hail. The damage to the roof is so extensive that I'd like to just replace the roof entirely if the roof bolts on (as Range Rovers do) as opposed to it being welded on. Does anyone knoe how the roof of the MCS is attached?
Jim
Old May 5, 2003 | 03:12 PM
chrisneal's Avatar
chrisneal
Why does this stuff only seem to happen in the first 1,000 miles on a brand new car? Good luck fixing her up; sorry I can't answer your question!
Old May 5, 2003 | 03:14 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Based solely on the "your the factory" video on the MINI website, it looks like the roof is welded on. Also, I haven't spotted any nuts or bolts holding my roof on.
Bummer about the hail damage though.
Old May 5, 2003 | 03:27 PM
Mister_S's Avatar
Mister_S
I believe the roof panel is actually attached with adhesive and then tack welded in critical places. Check out the factory tour stuff on MINI USA. I'd inquire with a top-notch body shop to compare replacement versus repairing the existing metal.
Best of luck to you.
With much sympathy,
James
Old May 5, 2003 | 04:59 PM
jsun's Avatar
jsun
Given that the roof is painted the same color as the body (and then painted white if so-ordered), I'm thinking it's welded on early in the assembly process. Before the paint. I know my "white" roof is really EB as I can see EB under the white in a few places where I've gotten stone chips in the roof paint.
Old May 5, 2003 | 08:22 PM
res0zvle@verizon.net's Avatar
Thanks for the info and sympathy guys. :smile: I can't get an answer from by body shop yet since they're so new. Once I find out, I'll let you know just for info purposes.
Thanks again
Jim
Old May 5, 2003 | 08:28 PM
SB's Avatar
SB
I'm not sure if you can tell if it is bolted or not by these photos. It was posted by someone who had a custom headliner installed. Look at gone.jpg, gone1.jpg and gone2.jpg. They show the roof of the car without the headliner. Maybe someone could tell from these pics if it is bolted or welded. http://www.djkaotix.com/mini/pics/pics/liner/
_________________
home.mchsi.com/~mini/index.html
Old May 6, 2003 | 10:21 AM
chollomo's Avatar
chollomo
ok if I didn't have a sun rook i'd be all abtou that..!! oh my gaod that is the best mod ever! I've never seen anyoen do that before..
Old May 6, 2003 | 12:41 PM
Wastik's Avatar
Wastik
The roof is most definitly welded on to the car.
To replace it the shop will have to cut the old skin off and weld a new one on. Then paint and reinstall the glass and parts.
If the hail damage isn't too bad I would look to repairing it. Or even better if you could go the paint-less dent repair way.
Wastik
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
NYMADMINI
Dec 14, 2016 02:33 PM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
