Interior/Exterior How do you get the Alta shifter to be less notchy
Old Feb 9, 2007 | 05:19 AM
fozworth's Avatar
fozworth
I have just fitted my Alta shifter and find the gear selection a bit notchy,its not realy a bother but i wounder if it will lessen in time .Also i have the shifter set at a low position and find the 6th gear a little hard to select .Its ok but you cant fight it other wise it wont select very well.Is this just a caracturistic of short shifters.As i said its probably something to do with a different shift pattern but i would like to know just in case i can adjust it.
Old Feb 9, 2007 | 06:32 AM
robino's Avatar
robino
had the same problem...
use the middle setting, it won't shorten your shifts dramatically, but it will make shifting more pleasurable, it is very notchy otherwise.
it will also 'give' a little with a couple weeks of shifting/you'll also get used to it and it won't seem so bad but the middle setting should cure most of your worries.
i do agree that the short shifter by Alta isn't what it should be...i've felt better (non mini cooper shifters but i've had better short shifters in my old cars)
Debi's Coop S
Dec 27, 2015 02:35 PM
02miniSguy
Nov 17, 2015 10:29 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
