Interior/Exterior JCW Steering Wheel Question
Ok I was hoping to be proved wrong, but Im only being proved half wrong at the moment.
I have the 2-spoke MFSW (03 build) so is the control wiring different or is it jus the placement of the buttons? For example, if I got controls out of a later build 3-spoke could I simply rewire it and use an airbag from a later build MINI? Prety much I want to be able to fit the JCW steering wheel into my 03 MCS without losing my airbag or MFSW controls.
Thanks,
BEATNUT
Thanks,
BEATNUT
Yeah doing this is only a thought at the moment, its not something I am all about at the moment just trying to think if it remains an option of if I should explore alternate routes to take.
BEATNUT
BEATNUT
One problem may be the number of things you can control. Keep in mind that the 3-spoke does not have a button that allows you to switch functions on the head unit. You can only switch between radion/CD/Aux from the head unit itself.
Dec 23, 2015 10:36 AM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
