Interior/Exterior REQUEST: Exploded diagram of side rail area...
Old Dec 5, 2006 | 12:28 PM
ImagoX's Avatar
ImagoX
Hey all...
Is there any chance that someone has an exploded diagram of the '06 (or, '05 I guess, if it's the same) MINI undercarriage? Specifically, I'm looking for info on exactly what's running along the underside of the car in the area beneath the running boards (so along the driver's and passenger sides of the car). I know that often fuel lines and control wires run along in there, and I'd like to know what's under there before I have the car up on jack stands, if you know what I mean. Info on fasteners and such is also helpful.
Thanks!
Old Dec 5, 2006 | 12:35 PM
agranger's Avatar
agranger
www.realoem.com <=== go here!
This has all of the part numbers by make/model/year w/ full diagrams.
Old Dec 5, 2006 | 12:40 PM
ImagoX's Avatar
ImagoX
Oh MAN, how did I LIVE without that?? That's great!
Thanks so much...
Old Dec 5, 2006 | 12:44 PM
agranger's Avatar
agranger
That's NAM for you... a question asked and answered in under 7 minutes...
Another satisfied NAM customer!
Old Dec 5, 2006 | 12:57 PM
ImagoX's Avatar
ImagoX
Hrm... still a bit hard to tell what's running under the "Door Entry Sill" trim peiice, though. I'll need to study these. But that's something, anyway. Thanks again!
Old Dec 5, 2006 | 01:12 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by ImagoX
Hey all...
Thanks!
I'm a little confused as to what your concern is.
Just put the jack stands under the lift points and you will be fine.
Old Dec 5, 2006 | 01:20 PM
ImagoX's Avatar
ImagoX
It's not lifting it... I'm just wondering what's hidden beneath the side sill trim pieces. I'd rather know ahead of time to orient myself, as opposed to trying to poke around while lying under a suspended peice of hardware weighing over 2,000 pounds. I need to take them off as part of something I'm working on and want to be sure I don't damage anything.
Yeah, I'm **** that way...
Old Dec 5, 2006 | 01:29 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Oh, ok.
Then good luck in your search. I'm sure there's someone here that has done Aero sides that could tell you.
Old Dec 5, 2006 | 01:35 PM
ImagoX's Avatar
ImagoX
Oh, that's a great point. Can someone that's installed the Aero kit chime in? Good suggestion - thanks!
Old Dec 5, 2006 | 02:13 PM
agranger's Avatar
agranger
I removed the stock side sills and mounted the aerokit side sills earlier this year.
There are a series of plastic clips that hold the sidesills in place (side sill = the large black normally unpainted piece under the door). You must destroy most of the clips to remove the sill from the car, so you will need to stop by your local dealer and get some new ones. One or two of the clips might be finessed off of the car, but it's generally a 'grip it and rip it' operation, starting near the front wheel and away from the car.
Look in the 'Vehicle Trim - Interior Body Trim Panel - Door Sill / Entrance Cover" diagram on realoem for more info on the clips needed, or just go to your local parts counter and tell them what you are planning to do.
The clips are usually $0.50 to $1.00 each. You should buy all new ones... don't get cheap and try to re-use a clip that has been pulled off because they stretch out of place and don't hold as well the second time around.
If there were any fuel lines, wires, etc, they were completely covered by sheet metal body panels.
Here is the official MINI instructions for mounting the aerokit (courtesy of www.motoringfile.com): http://www.motoringfile.com/howto/Ae...%20Bodykit.PDF
Old Dec 5, 2006 | 02:20 PM
ImagoX's Avatar
ImagoX
You da man, AGRANGER - thanks again!!
STR3T
May 23, 2016 03:27 AM
khumpert
Nov 30, 2015 11:48 AM
1chaos52
Aug 24, 2015 01:28 PM
penguinhomey
Aug 19, 2015 01:14 PM
cm.d
Aug 19, 2015 08:51 AM
