Interior/Exterior anyone have the chrome roof?
Old Nov 29, 2006 | 06:24 PM
  #26
Jtrem's Avatar
Jtrem
Originally Posted by riquiscott
The paint that they used for that car, ALSAcorp's "Mirrachrome", doesn't quite have all of the shine and distinctness-of-image of true chrome, but it's by far the best "chrome-effect" paint I've ever seen. And it's perfect for soft plastic parts (like polyurethane ground effects kits) that can't be vacuum-plated, or for parts that would be prohibitively difficult to remove from the car to dip-chrome.
The biggest drawback is the cost. It's $150 for eight ounces, or $1200 per gallon. Plus, it's delivered "ready-to-spray", which means that you don't mix it with reducers or catalysts before applying it. With other uber-expensive paints, a $1200 gallon gets mixed with reducer to give you 1-1/2 or 2 gallons of sprayable paint. With the Mirrachrome, one gallon means one gallon, so the cost per *sprayable* ounce might even be higher than some of the exotic colour-shifting paints like House of Kolor's "Kameleon" paint that sells for almost $2000 per gallon.
Scott
I dont know why House of Kolor's gets so much for the Kameleon its not even that great! I dont see how it changes colors. Always looks purplish.
Old Nov 29, 2006 | 06:51 PM
  #27
ScottRiqui's Avatar
ScottRiqui
Actually, I've found the HoK brand to have pretty dramatic colour shifts. A lot of it depends on what colour base coat you use under it, as well as which particular Kameleon paint you choose. They have red-to-gold, cyan-to-purple, silver-to-green, green-to-purple, magenta-to-gold, gold-to-silver, blue-to-red, green-to-blue, copper-to-green, gold-to-green, and a sapphire that they admit only has a limited colour shift.
http://images.andale.com/f2/118/116/...OK_KFO8car.JPG
http://images.andale.com/f2/118/116/...K_KFO6_car.JPG
Old Nov 29, 2006 | 11:18 PM
  #28
Jtrem's Avatar
Jtrem
I sure hope someone buys this im curious to see what its like!
Old Nov 29, 2006 | 11:54 PM
  #29
MINIclo's Avatar
MINIclo
7th Gear Gal
Scott
Thanks for the info, Scott. I'd like my bonnet stripes painted using that Mirrachrome paint! The vinyl ones are too fragile. I wonder how tough the Mirrachrome is?
Old Nov 29, 2006 | 11:56 PM
  #30
Jtrem's Avatar
Jtrem
I imagine way tougher than Vinyl!
Old Nov 30, 2006 | 04:04 AM
  #31
ScottRiqui's Avatar
ScottRiqui
Well, Mirrachrome is designed to be followed up with automotive clearcoat, so it shouldn't be any more fragile than the paint anywhere else on your car. Plus, that means that you could bury the stripes in the clearcoat so that you wouldn't be able to see/feel a ridge at the edge of the stripe.
Scott
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
wyliec0y0te
Sep 15, 2015 01:13 PM
freckles81
Sep 8, 2015 09:48 AM
