Interior/Exterior Gauge Help
Old Oct 29, 2006 | 05:37 AM
  #26
mbcoops's Avatar
mbcoops
That looks awesome, but how are you going to deal with the extreme temps when you need heat or AC?
mb
Old Oct 29, 2006 | 06:13 AM
  #27
ScottRiqui's Avatar
ScottRiqui
mb
There are plenty of other vents in the car - losing those two won't make much of a difference. The "upper vents" (defroster) and "lower vents" (footwell) are unaffected, and there are two more "middle vents", one at each end of the dashboard.
Plus, I have a convertible, so I generally have the top down more often than I use the A/C anyway.
Scott
Old Oct 29, 2006 | 03:03 PM
  #28
Smokey's Avatar
Smokey
I went with the Alta Pod and used Autometer 2 1/16" gauges. I used mechanical and although everything is working fine, I'd go with electrical if I was to do it again. I know the elec are about 3 times the cost of the mech, but the amount of work required to do a clean install with the mechanical was trememdous.
Since you're going with a Oil Temp gauge, you might have a easier go at it but with my oil pressure gauge, it required me to relocate the pressure sensor and work up a hook-up fixture. Even though the parts are easily found at your local home store, they are a bit of a b1tch to install. You'll be working blindly or with your arms jammed up through the suspension members to get everything hooked up. The wiring harness won't let you move the pressure sensor very far and you'll need a odd size (27mm 6-point) deep socket to get the pressure sensor out.
I think the elec would be cleaner behind the gauges as well. Here is a shot of mine. Notice the copper line going to the oil pressure and the nylon line is for the boost.
Make sure you use a few zip ties to secure the connections of the nylon lines at the adapters and T-fittings. Mine blew off the provided "T" in about a week and I had to go back and remove the I/C once again.
Here's a shot of my plumbing down at the pressure sensor:
I've also gone back and reworked the fittings to move the plastic connection further away from the cat, plus I've shielded the whole thing with some hightemp plug-wire wrap to stop it from melting!
Good luck and let me know if I can help.
BTW, the gauge pod is shallow and the gauges are deep, so I painted mine flat black to reduce their appearance
Old Oct 29, 2006 | 03:21 PM
  #29
mini-rolls's Avatar
mini-rolls
Smokey the install looks good.
Old Oct 29, 2006 | 03:44 PM
  #30
Smokey's Avatar
Smokey
It's fun watching the gauge bounce from a vac of 22 to a boost of 14 But honestly it more for dress then function. The oil pressure on the other hand is very usefull.
Those pic's don't show it, but I've wrapped the copper line with a plastic wire loom from the gauge all the way to just above the heat shield to remove all vibration induced rattle. I had the locations where I thought I'd get some taped, but on the first couple of test drives I got tired of pulling the euroshelf and tach mounts to tape spots and just gave up and wrapped the entire line . Quite as a church mouse now
Old Oct 29, 2006 | 03:54 PM
  #31
mbcoops's Avatar
mbcoops
Thanks for the specific help! Whatever gauges I get, I am not installing them myself - I lack basic mechanical skills. I wonder if the cravenspeed pod lets the gauges sit farther back and more flush.
mb
Old Oct 29, 2006 | 04:43 PM
  #32
mbcoops's Avatar
mbcoops
Ok, I'm pretty sure this is what I'm going to get:
Autometer full sweep electrical boost and oil temp, part #s 4377 and 4356 in 2 1/16 size.
They will either go in this:
http://outmotoring.com/mini_gauge_pod.html
Or this:
http://outmotoring.com/cravenspeed_g...nt_system.html
And if outmotoring is willing to swap for me, then maybe they'll be part of this:
http://outmotoring.com/mini_cooper_gauge_kit.html
If that works, I'd have to get the larger ones. That probably isn't the cost effective way to go. Since I want the information and the look really is secondary, I'm leaning towards the 34$ stock pods that go behind the lighter.
mb
Old Oct 29, 2006 | 06:12 PM
  #33
Smokey's Avatar
Smokey
Nice! I've seen the Craven pod at the Dragon and I liked it. Nice construction and a trick kind of mounting system. The reason I went with Alta was because I was able to pick it up used at 50% off otherwise Craven might have been it.
Are you buying your own gauges? If so give Summit Racing a look see. For my choices they were best price even with shipping.
Good Luck and have you checked with your installer? They might be able to get a better price.
Old Oct 29, 2006 | 06:54 PM
  #34
mbcoops's Avatar
mbcoops
Yep - I've got the page up, and I'm ready to "add to cart" from JEGS (prices are the same as summit and their site is much easier to browse/find the gauges).
Edit - not sure who's going to do the install yet - I'll probably give Eric at Helix a call. If not then maybe Motor Works West in NJ.
mb
Old Oct 29, 2006 | 07:20 PM
  #35
Smokey's Avatar
Smokey
Might want to check out the Marketplace, guy there has a few gauges for sale.
Old Oct 30, 2006 | 04:55 PM
  #36
mbcoops's Avatar
mbcoops
Has anyone ever tried these:
www.speedhut.com It's fun making your own gauge!
mb
Old Oct 30, 2006 | 05:52 PM
  #37
herbie hind's Avatar
herbie hind
Edit - I spelled GAUGE wrong. If you're an ***, you'll probably comment. If not, please stick to the substance of the question. Gauge will remain incorrectly spelled for reasons of principle. Or is it principal. The infinitely smart of this board should share.
I searched through the guage threads and have made some decisions but also have some questions.
I'm going to buy Alta's guage pod and autometer guages to go in it.
I want boost and oil temp. Should both of those be "mechanical"? Also, what range should I get for oil temp - up to 280 deg. F or 340?
My car is used both on the street and track.
Thanks!
mb
okay... i just finished my oil temp / pressure guages by auto meter in the alta pod. first be prepared to mod the pod. especially if you're using autometer. 2" pvc with eand plugs but glued works awsome but you gotta have a belt sander at your disposal. once you've made some nice tubes you can secure them with the alta allen screws. then paint all flat black. it really looks like aluminum when done . the electrics are easy too. though the autometers could double as landing lites. i gotta look into a different led for them. i'd go electric if i were you . though the boost isn't a big deal to go mechanical. madness has a pod with a back on it if you want to spend a little more money ;maybe 20.00
Old Oct 30, 2006 | 05:56 PM
  #38
herbie hind
Is it true that the 60mm (2 3/8) gauges are the only ones that fit in the Alta pod? Autometer only lists 52mm (2 1/16) on their site - will they fit, too?
mb
2 1/16 work fine alta sends a rubber spacer. but if you don't want the ugly wires looking at everyone from the outside you'll need to go with a tube of some sort like(pvc).
Old Oct 30, 2006 | 06:10 PM
  #39
Smokey's Avatar
Smokey
Did you shape the PVC to fit the dash curve? That would look very, very clean
To clean mine up I wrapped the wires for the lights with e-tape. BTW, you can get an orange bulb for the autoparts place to replace the white. Do you have pic's of your install?
Old Oct 30, 2006 | 07:02 PM
  #40
chuckt's Avatar
chuckt
okay... i just finished my oil temp / pressure guages by auto meter in the alta pod. first be prepared to mod the pod...
Which size gauge did you go with? I'm assuming 2-1/16" but I know someone said the 2-5/8" gauges would fit in the Alta pod... If so, I'd like to see a pic it.
Old Oct 31, 2006 | 01:02 PM
  #41
herbie hind
no pics ; but if you look at the alta pod it's notched on the rt.(looking out) to clear the dash. i just ran my pvc tube flush with the inner portion of this notch on that side. on the other i made the tube about a 1/4 " shorter to even um out. 21/16" gauges fit fine in the 2" pvc. the pvc once sanded a bit fits perfect in the alta pod. go to lowes and look in plumbing find the hexagonal plugs that but up to 2" pvc. just glue together. then sand off the hexagonal part. this makes a very nice tube with cover. simply drill a hole the same size as the wire harness you're running . black is nice, paint all including the alta pod(sand a little) flat black. it looks awsome.
Old Oct 31, 2006 | 01:05 PM
  #42
herbie hind
i went with the nv gauge series. they're nice but very bright. the dimmer barely dims them. i'm getting a dimmer from atm for them. if i knew how to post pics i'd give it a try.
Old Oct 31, 2006 | 01:09 PM
  #43
Smokey's Avatar
Smokey
email them to me and I'll put them up here for you. smokey4(at)roadfly.org
Old Oct 31, 2006 | 01:20 PM
  #44
herbie hind
i'll go shoot em now.
Old Oct 31, 2006 | 02:34 PM
  #45
Smokey's Avatar
Smokey
Ok here are Herbie's shots
Old Oct 31, 2006 | 02:41 PM
  #46
herbie hind
wow big!! thx for posting smokey
Old Jun 27, 2007 | 08:31 PM
  #47
Bullet2006's Avatar
Bullet2006
Gauges in center air vents
Does anyone have any instructions to do this type of gauge installation?
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
