Interior/Exterior HID ion projector fog lights!
Old Aug 25, 2006 | 10:43 PM
  #26
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by 02///MCS
Hmm that clears up what I was wondering, thanks for the post. Only disagreement is your statement about the HID being "very inefficient" in a Halogen housing. Very inefficient would mean it doesn't provide enough light, which is a false statement as although it might not be as effective as an HID in a housing intended for HIDs, it still provides VERY useful light and probably more light than the Halogen bulb itself. To each their own.
It would be inefficient. You are using a $300-$500 HID setup to make LESS light than the $20 halogen bulb that came with the lights. I would call that pretty ineffective . I didn't say use-less.....just not effective.
To each their own for sure....but what i don't understand is why not just use xenon-look bulbs? You would get all of the same things but save money
Old Aug 26, 2006 | 09:53 AM
  #27
Wake|MCS's Avatar
Wake|MCS
Well for starters, the xenon-look bulbs don't quite match perfectly. And idk even with the proof you showed me, I'm stubborn lol. I've had several friends do HID-conversions and not only do they work, they provide more light output than their halogens. At least thats the way it seems to the untrained eye lol. Just stubborn...
Old Aug 26, 2006 | 11:21 PM
  #28
One-D's Avatar
One-D
My brother put HIDs on his Audi with non-xenon projectors and they work just fine. Seems to be with correct pointing and gets a tremendous amount of light output. In essence, what exactly makes a halogen projecter so different from an HID projector? The if the light is coming from a source, the bulb, that is the same distance fromt he tip of the projector as intended, why would that be any different?
P.S.: This is a genuine and serious question, I would actually like to know so as to make sure my fogs are functional as well as look good...
Which.... the real difference between the two Valeo projectors are the base for the bulb seating-- H7 vs. D2S.
Old Aug 27, 2006 | 09:26 AM
  #29
Wake|MCS's Avatar
Wake|MCS
Ok, so other than that (which is what I thought was the only difference) are there any other differences between the 2 projectors?
Old Aug 27, 2006 | 10:01 AM
  #30
One-D's Avatar
One-D
not really. Then there are differences between US and Euro projectors (lens).
But you know Hella does offer a HID fog projector in their economy (cheapo) Optilux lineup? Only $600+ for a set.
Old Aug 28, 2006 | 12:41 PM
  #31
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The bulbs shown in this picture are NOT HID bulbs, rather they are simple blue-tinted H3 halogen lamps. One problem with finding small projector HID lamp assemblies is the fact that the ballasts (the electronic high voltage power converters) needed by a true HID bulb are often bigger than the actual lamp assembly, and need to be mounted fairly close to the lamp assemblies themselves.
So many lamp manufacturers play games with the nomenclature to sell you something that's not what it is sold as.
"Xenon" can apply to a true HID lamp or a simple halogen incandescent bulb. It refers to the filling gas inside the bulb itself. Even MINI boasts of 'xenon' interior lighting. Technically, even the standard halogen headlights on MINIs are 'xenon'.
HID can only mean that: High Intensity Discharge. A discharge lamp does not use a filament, instead it uses an ampule of gas that is energized (excited) by a high voltage, high frequency electric current applied to electrodes inside the ampule. Since a car's electric system is 12 volts DC, a complex circuit is needed to convert this into the several thousand volts and many kilohertz needed to fire the gas and maintain the ionization. A mercury vapor outdoor area light is a HID lamp, as are the golden colored sodium lights you see everywhere along the streets at night.
Terms like plasma ion, xenon, HID Blue and the like are marketing terms for blue colored, filtered light from standard halogen bulbs. The sure-fire way to determine if a lamp is truly a HID assembly is the presence of a ballast for each lamp, and an extra zero in the price tag.
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Aug 19, 2015 12:51 PM
AZN Optics
Aug 16, 2015 11:52 PM
