Interior/Exterior Driving lights-Bolts instead of rivits.
Old Jun 8, 2006 | 01:29 PM
qwertmonkey's Avatar
qwertmonkey
Has any one used bolts, lock washers and nuts instead of rivits? Are there any risks with going that route?
Thanks,
William
Old Jun 8, 2006 | 01:37 PM
chows4us's Avatar
chows4us
The rivets are used on the OEM brackets. Rock solid
I have bolts on the fogs. They do loosen up. But, you also want to be able to adjust them. I can't adjust (I dont see how) the driving lights. A little bit of locktite will do the trick Just used the one that is not permanent.
Old Jun 8, 2006 | 01:50 PM
Minirox's Avatar
Minirox
The deal with the brackets is you are drilling into the plastic grill as well as the thin metal on the bottom there is no way to put a nut and bolt. Thats why the rivits. Do your lay out of the brackets and you will see what I mean.
Old Jun 8, 2006 | 02:01 PM
locomini's Avatar
locomini
you can do this
https://www.northamericanmotoring.co...ight=piaa+5430
Old Jun 8, 2006 | 02:16 PM
qwertmonkey
Hmm. I used nuts and bolts with no problems. It was a little tricky, but nothing unusual.
Old Jun 8, 2006 | 02:17 PM
qwertmonkey
That is kind of what I did, but I did it the other way around; nut on bottom.
Originally Posted by locomini
Old Jun 8, 2006 | 03:13 PM
Minirox's Avatar
Minirox
I stand corrected. The rivits done correctly don't show from the outside.
Old Jun 8, 2006 | 03:27 PM
qwertmonkey
Ohhh! I gotch ya. I dont notice the bolts, no its fine by me. I guess its personal preferance.
Old Jun 8, 2006 | 05:45 PM
Minirox's Avatar
Minirox
That's whats cool about the Mini. It is all personal preference. Everyone has the perfect Mini for them. There is no other car on the market like it.
Old Jun 8, 2006 | 06:04 PM
qwertmonkey
You better believe it! If any one disagrees, thay aint a true MINI owner!
Old Jun 9, 2006 | 06:51 AM
SonicVI's Avatar
SonicVI
I used rivets on the grill and nuts/bolts on the bonnet, only because the brackets didn't quite reach the underside of the bonnet and rivets wouldn't have worked. I guess they changed the underside of the bonnet slightly for '06?
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Aug 19, 2015 09:12 AM
Emnotek
Aug 13, 2015 05:47 PM
xpunisherx
Aug 10, 2015 10:50 PM
