Interior/Exterior Racing harness + stock seats = royal PITA?
Old May 10, 2006 | 06:56 PM
not-so-rednwhitecooper
Ok, i have a conventional 4 point harness now.
i think i can manage mounting the harness in the rear and on the left side of the driver seat, but the right side, near the console, its really tight!
does anyone with stock seats run a harness that isnt a schroth? i need to figure out a place to mount the right side lap belt.
Old May 10, 2006 | 07:19 PM
xizor's Avatar
xizor
just unbolt the seat from the rails, its only 8 bolts. then tip the seat to a side so you can get the belt mount in there and then put it back. you need a 55 torx for the seat belt I think
Old May 10, 2006 | 07:26 PM
like sandwhich the eyelet from the harness underneath the seat rail and the clip in part run the seat belt bolt thru it?
Old May 10, 2006 | 08:00 PM
90STX's Avatar
90STX
The same capscrew will end up going through both the stock seatbelt mount and the mounting plate for the harness. The only point in tipping the seat sideways is to gain some room to work in.
There is plenty of thread engagement on the capscrew, even with the harness plate on there.
How are you attaching the shoulder belts? Are you installing this for autocrossing, or open track work? There are some safety considerations, depending on your intended use.
Scott
90SM
Old May 10, 2006 | 08:17 PM
Its merely for Autox, just want to plant me in the seat a bit better.
I'll see what i can do and see if i can get this thing in there now!
Old May 10, 2006 | 08:38 PM
90STX's Avatar
90STX
Okay. The lap belt install shouldn't take you very long. You don't even need to disconnect the wiring harness from the seat.
For autocross only, I use a y-belt style shoulder harness with clip-on style end (intended to snap onto an eyebolt mount). I lower the rear seat, and clip it to the d-ring type mount that the rear seatback latches too. The other end is passed through under the headrest (between the posts) to keep the belts from sliding off either side. The end result is that the shoulder belts go pretty much straight back at a nice angle. I leave the lap belts in all the time, and just clip the shoulder belt in when I'm at an event.
For others, this attachment point is not suitable for track work. It should also not be used on the street. Just autocrossing.
Good luck. I've been using this setup (Simpson cam-lock 5 point) since late 2002.
Scott
90SM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
eatsleepautox
Oct 30, 2015 06:46 AM
PhoenixR61
Aug 19, 2015 10:27 PM
