Interior/Exterior hood stripes and steering wheel compatibility
Old Apr 14, 2006 | 06:09 PM
Saaboteur's Avatar
Saaboteur
Couple questions. I've acquired a set of factory hood stripes. Are there any online factory instructions? I want to know what the factory says for precise placement of the stripes.
I'm also contemplating buying a triple spoke steering wheel from the marketplace, off an '06 car. I've got an '02 - should fit? Splines should be the same? Any wiring issues? I don't have any steering wheel mounted controls other than the horn.
Any help appreciated.
Old Apr 14, 2006 | 06:18 PM
Hngn on n the psnger seat's Avatar
Ok so i really dont have an answer to your question but i had to say that my foggy brain was wondering why your hood stripes wouldnt be compatible with your steering wheel
I am sure somebody will be able to help
Old Apr 14, 2006 | 06:21 PM
bumble's angel's Avatar
bumble's angel
Some one on here has an 02-04 steering wheel on their 05-06 MINI. So I think they are compatible.
Old Apr 14, 2006 | 06:40 PM
CustomAV's Avatar
CustomAV
Didn't you know that you must make sure that the stripes are in proper alignement with the center spoke of the wheel. Considering the angles of deflection on the bonnet and the curve of the earth it may be impossible to achive this, thus the compatibility is a problem....
I couldn't help it... cut myself off early at the bar tonight and decided to become a pest on NAM instead
chris
Old Apr 14, 2006 | 07:00 PM
MSFITOY's Avatar
MSFITOY
chris
You think steering/stripe alignment is tough...I've spent all day aligning my cross drilled strut tower to the yellow road stipes...still don't know who wrote the instructions for this skit Enough of that...I'm moving on to the 500cc oil vacuum gauge install...
Old Apr 14, 2006 | 08:18 PM
CustomAV's Avatar
CustomAV
only you Sid.... only you....
although I did just spend 20 freaking minutes trying to get my newly covered red leather door armrests back into position!!!!... Who in the h*&^ designed that attachment.....
woodstudio
Mar 15, 2020 08:28 AM
ebowling
90
Aug 4, 2019 09:15 AM
Dec 23, 2015 10:36 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
