Interior/Exterior Lower Areo grille install ?
Old Jan 28, 2006 | 10:23 PM
studog's Avatar
studog
Has anyone has any success doing the lower grille without removing
the bumper cover? Or can someone post a link.
Thanks all.
Studog
Old Jan 29, 2006 | 08:22 AM
Blakc's Avatar
Blakc
It can be done if you are careful. Just use a small flat screwdriver in one of the corners. Wrap the tip in some tape and pry. Once the one side is loose the rest comes off very easily. Just take your time and save yourself the removal of your bumper.
Old Jan 29, 2006 | 08:51 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Removing the front bumper cover is really an easy job.
I'd rather tale the extra 10 minutes to remove it than damaging the bumoer to save 10-20 minutes.
Old Jan 29, 2006 | 08:53 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Agreed. Removing the bumper is just a few screws and 2 torx. It's much safer to take your time, and do it right. Even if it takes an extra half hour
Old Jan 29, 2006 | 09:43 AM
Justanthony's Avatar
Justanthony
here's a link
here is a link to my install without removing the bumper. not hard at all and if you are careful, you run no big risk of damaging your bumper.
https://www.northamericanmotoring.co...ht=color+coded
Old Jan 29, 2006 | 06:13 PM
studog's Avatar
studog
Thanks, I have the top in. I'm doing the lower on Sat I'll let you know how it goes.
Old Jan 29, 2006 | 08:30 PM
Justanthony
cool. just be careful not to trim too much if you plan on leaving that center slat in! take a little bit off at a time.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
